3 spd to automatic conversion.
Outside of a steering column and transmission,what else is needed to convert my 68 c10
to automatic?will my lowershaft on the 3spd swap over to an automatic column? Thanks! Posted via Mobile Device Posted via Mobile Device |
Burnouts are therapeutic
Re: 3 spd to automatic conversion.
linkage, crossmember,torque converter and flexplate will be needed and you might have to remove the crossmember thats there now ,if its like the ones I've removed they are riveted in.
You will also need a trans cooler or a radiator with one. not sure what else you might need, but I'm sure someone else will help out.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
