04-26-2003, 10:29 PM | #1 |
Failure is NOT an option!
What order?
What order do you usually replace panels?Corners then floors then rockers?Will I have to tie the cab together some way to keep it from spreading when floors are cut out?
04-27-2003, 08:19 AM | #2 |
1969 Custom 30 wrecker
I can't say what anyone else is doing but im doing my second truck right now and I always do the rocker first. Then you can go to floor or cab corner. Be sure to only tack in the rocker and put door back on to check the gap at the bottom. Once it looks right, weld it in fully.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
