01-18-2012, 08:34 PM | #1 |
4WD to 2WD
Anyone know if 2WD and 4Wd frames are interchangable?
thanx
65 burb On the road Mar 26th Finally |
01-18-2012, 08:47 PM | #2 |
Re: 4WD to 2WD
The frames are different but you can convert a GMC 2wd to 4wd the GMC already have leaf spring rear or if you want to convert a 4wd to 2wd that would be easy just remove the front spring hangers and bolt in a 2wd cross member then just remove the factory lift blocks from the rear and loose the transfer case .
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! Last edited by duallyjams; 01-18-2012 at 08:54 PM. |
01-18-2012, 11:11 PM | #3 |
Re: 4WD to 2WD
the frames are close to the same i changed 2wd frame to 4wd and left the trailing arms in the rear just for flat track mud racing.A days job piece of cake.
triple d |
01-19-2012, 02:46 AM | #4 |
60-66 Nut
Re: 4WD to 2WD
The K series frames are deeper from the front of the cab to the rear where the frame starts to curve up. They also don't have the kick out in the frame where the coil springs would be for a C series truck.
