![]() Join Date: Mar 2010
ANyone tell me if a 4WD blazer chassis can be used in 2WD configuration?
In other words with 2WD suspension bolt in a 4wd chassis? thanks in advance
65 burb On the road Mar 26th Finally |
Too Dumb To Know Better
Re: 4WD to 2wD
Works great. It is done alot. Livrat is the king of this conversion. There are alot of them on here.
SKINNY TIRES RULE!
Re: 4WD to 2wD
Sport truck magazine did an article showing the steps to convert. http://www.sporttruck.com/techarticl...ion/index.html
If you plan on going low, you can get lower with the 4wd frame converted than with a 2wd frame.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
needs more $$$
Re: 4WD to 2wD
No problem in the front, but I don't think you can use the trailing arm rear if that's what you were planning.
1970 2wd Blazer |
SKINNY TIRES RULE!
Re: 4WD to 2wD
The article shows how to install trailing arms in the rear. You have to fab/install some mounts for the shocks/airbags.
SKINNY TIRES RULE!
Re: 4WD to 2wD
If you want to do it quick, you can use the leaf springs and put the axle on top.
needs more $$$
Re: 4WD to 2wD
Sorry about that...but for what it's worth, anything's possible with a welder and fab skills. I kinda figured he meant a true "bolt on" swap. The article does make it seem very simple though.
1970 2wd Blazer |
SKINNY TIRES RULE!
Re: 4WD to 2wD
You are right. If you want just bolt on, using the leaf springs and putting the axle on top is the easiest.
#9 | |
Re: 4WD to 2wD
Takes a good bit of work to cut or drill out all rivets from a 4x4 chassis. You will need to add trailing arms with coil springs or bag it. front cross member from a donor truck with disk brakes. rework exhaust and brake lines. Different trans, and drive shaft relocate shocks. The short answer was (Yes) its been done. |
