Old 04-26-2003, 11:57 PM   #1
Mudder
Mudder's Avatar
Gas pedal ?
Has anyone ever gone to the cable from the rod type gas pedal linkage? Is it hard to change or would I want to?
Mudder is offline   Reply With Quote
Old 04-27-2003, 12:10 AM   #2
Class of 69
Class of 69's Avatar
It's a pretty easy change. Allows the engine to flex without binding the rod. If a motor mount ever breaks when your gassing on it, the rod likes to stick in the wide open position, where as the cable won't. If your interested, I have an extra one available...$30.00 shipped to your door via USPS.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 04-27-2003, 02:38 AM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Let me know wher you find a new cable at Mudder, I need one for my 72. Any place I've checked as far as local stores only list 2wd, 4x4 seems to be a dirty word for some reason.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-27-2003, 09:30 AM   #4
Mudder
Mudder's Avatar
Wonder what the difference would be? I have a 2wheel drive cab.....Hmmmm.
Old 04-27-2003, 10:02 AM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I think the difference is in the length of the cable, 2 wheel drive being longer than the 4x4 version because the motor sits farther away from the firewall on 2 wheel drive.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
