Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-19-2012, 10:20 AM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
annoyed help. (carb set up)
ok yall.. im not going to tell the following.
jets installed, secondary spring installed, timing set at, and advance springs in distro.
Id like to see yalls input.. my current set up has me "flattening out" bad at 4 grand... which is weird.. i cant figure out why.... ( i keep tweaking but ive been so all over the place that i just need to start from the beginning)
I need to get a new timing tape on my dang balancer also..
SO! here's the list of things done ((yall have seen it before))
PLEASE tell me what you would run for jets, timing(initial) and advance springs.
sbc 350, stock pistons, bottom end
Patriot sbc 23 degree heads
aluminum heads
190cc runners
2.02 intake
1.60 Exhaust
Hardened steel seats
Max life .575.
.750 reach, gasket seat angle head plugs
cam
RENEGADE PN 158881
dur@.050 Int 234 exh 244
vaulve lift int .488 exh .510
intake edlebrock perfromer RPM
carb holley 670 carb with a 7.5 power valve. (8.5 is way to rich.. 6.5 causes serious delay)
MSD box/cap wires/rotor
accell distruibutor.
headers thru exhaust.
all connected to a built th350 with 2600 stall. going out to a 2.41 rear (3.73 posi swap soon) in my camaro.
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-19-2012, 05:30 PM   #2
dinnut
dinnut's Avatar
Re: annoyed help. (carb set up)
Are you sure the secondaries are working? I had a motor very similar to that and it was very picky with the Timing. Had to run the lightest springs I could find. But if your losing power I'd try another Carb and see if it fixes the problem. I had a couple carbs where the secondaries wouldn't work and it would fall on its face around 4k
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-19-2012, 06:23 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Get an Air/Fuel gage connected in and see what happens at 4k. It may not even be fuel related.
dwcsr is offline   Reply With Quote
Old 01-19-2012, 08:23 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: annoyed help. (carb set up)
Carburetor Installation & Tuning Segments
Everything you ever wanted to know about Holley Carburetors.
Segments include 3D virtual tours, exploded views of actual carburetors, step-by-step under the hood installation, advanced tuning and troubleshooting.
http://www.youtube.com/user/HolleyPe...3239D6A7D7BFF0
http://www.holley.com/TechService/Library.asp
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-19-2012, 11:26 PM   #5
dammitmitchell
the pollock
i love you so much right now... (in a brotherly sorta way)
Army vet 02-08
