Old 04-27-2003, 12:55 AM   #1
71gmcfanatic
tranny swap
I currently have a turbo 350 in my truck but soon plan to swap to a turbo 400 because im going big block. My question is which Turbo 400 will be the easiest to swap in the place of my original t350? What will I need to do to swap from a t350 to a turbo 400?
1971 gmc 3/4 ton, 350, t350
71gmcfanatic is offline   Reply With Quote
Old 04-27-2003, 03:24 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If your big block is stock, you can run a TH350 with no problems at all, even some big blocks with light mods push TH350 without killing them.
However, in reality, the 400 will last longer.
Are you aware that you'll probably have to convert to a high hump floor on your cab?
