72 c20 rearend ?
did all the 72 c20s have the same rearend? if not whats a simple way to identify the one in mine?
Moderator
![]() Join Date: May 2007
Re: 72 c20 rearend ?
dana 60 or eaton. eaton has a round diff cover, dana 60 has a more square shaped diff cover.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Florida Edition
![]() ![]() Join Date: Oct 2010
Hey grace, welcome aboard from Central Florida!
Here is a 72 Dana 60 in a 3/4 ton.....
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
thanks for the info!! helps me a ton!!
My 71 c20 has a dana 60 with leaf springs, but i have also seen them with coil springs. The strangest thing was my original carrier and spider gears were shot and i thought i would never find a good used carrier for it, but i bought a NEW dana 60 complete carrier for a 99 dodge 2500. It fit like a glove. I just bolted my ring gear on, 3-4 blows from a soft heavy mallet, and it was in. I got lucky and the gears meshed perfectly. Whats even more unique is that the carrier came with a rear speed sensor ring pressed on lol.
Would a person be able to change gear ratio by finding one of these later model rear end carriers ? I have a 72 C20 with 4:10 gears and would like to go with a mid three ratio.Or can the ratio be changed with just a gear change ? Aren't the carriers different from a 4 ratio to a 3 ratio ? This is an area that I don't know a lot about so I appreciate any and all information I can get !!! Thank You . Have a great day !! Tom |
Ttt
![]() Join Date: Oct 2009
take a look at posts 20-25 of this thread, MIGHT help, might not - Special-K is one of my go to guys for rear gearing questions!
http://67-72chevytrucks.com/vboard/s...d.php?t=507864 |
Here, these are fun places to look around.
Dana Spicer general information. http://www2.dana.com/pdf/XGI.pdf Dana 60 specific http://www2.dana.com/pdf/5309-3.pdf
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
SS Tim
Thank You !!! Those links are great !!! |
