so crazy idea
I had this idea I am tired of the tree on the tree. It really kills the 0-60 times on my truck could just be me who knows. But I had an idea I have a t-5 out of a mustang laying around do yall think that I could bolt that up to a 350?
Re: so crazy idea
It's not cost effective to adapt the Ford T5 to a chevrolet, but it can be done. Try and trade it for a GM V8 T5. They are a little hard to find, but out there. Search here for swapping in the 6 cylinder T5 which works great, just don't hammer on it.
Re: so crazy idea
A T5 won't hold up. Get a T56 and do it right the first time. I have a T56 in my '72 V8 Vega and I BEAT on it. No problems.
Webmaster: www.h-body.org |
The Older Generation
Re: so crazy idea
I have an S-10 5 speed in my '67 LWB and I beat on it pretty hard... 0-60 in about 5 minutes. Oh, it's an Inline 6 too.. ![]() LockDoc
![]() Join Date: Oct 2009
Re: so crazy idea
0-60 times and T5 should never inhabit the same sentence (even a WC T5). I really like mine, but I hammer on it about as much as LockDoc. It's a driver and I would like to keep it driving, so I don't hammer. If building a hot rod, concur with Colin, go with a T56, or find an old Doug Nash 5 sp - or an automatic (sorry, said the "a" word...)
Fabricate till you "puke"
Re: so crazy idea
If you want some fun on the cheap(assuming a 275-300 hp motor), go dig up a saginaw 4spd, with 3 rings on the input shaft. Its a wide ratio box, but with a low(3.50 1st gear). Ratios go IIRC 3.5/2.5/ 1.7/ 1. There is a long stretch tween 3rd & 4th, but the truck is rolling hard by then! the box will take some guff, but I would not reccomend slicks or drag race useage. I ran one 25000 miles behind a 300 hp 327, & drove the truck like I stole it....finally fubared it behind a 355 in my old Longhorn(6500 rpm shift in 3rd gear, loud peddle to the metal)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#7 | |
C-10 Club Member
Re: so crazy idea
They don't really like to be speed shifted ![]() ![]() Found 2.5 one day playing around with my friends chevelle and had to litteraly use every bit of strength I had to un wedge it. it will scratch 2-3 good though.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
#8 | |
Re: so crazy idea
Re: so crazy idea
Re: so crazy idea
t5 out of the mustang isn't that bad. They beat on them like stolen cars all day long.There is a bellhousing that will bolt it all together. Comes from an early 80's amc spirit (really!) 4cyl 5 speed. The 4 cyl. is the old iron duke from the monza , t5 bolts to it.
