Old 01-19-2012, 08:51 PM   #1
PaRedneckRiders
Twin stick really worth it?
Picked up an np205 off my buddy in trade for my 208, idk he just really wanted a 208. But anyway im going to pull it apart to clean it and paint it prob replace bearings seals and gaskets but i was wondering if i should go ahead and turn it into a twin stick case. I have been toying around with the idea for a while now but im not sure if there is ever going to be an instance where i need to be able to use the axles separately.
For anyone that has done it do you think it was worth it or do you think you should have just left it single stick.
Its going to be in my woods/mud truck.
PaRedneckRiders is offline   Reply With Quote
Old 01-19-2012, 09:32 PM   #2
1969K10
1969K10's Avatar
Re: Twin stick really worth it?
I don't think there is any great advantage to having one. However, when I bought mine, it was cheaper than a single stick. That being said, I think engaging the front axle is much easier (smoother) w/ a twin than a single. For what it's worth, I didn't finish the conversion, I can't engage the front unless the rear is already there, just installed the twin sticks.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-19-2012, 10:19 PM   #3
turp mcspray
turp mcspray's Avatar
I ran a home made twin stick for many years. I used 2 lo, all the time in the woods. To me, that was main reason for it. After having it, I'm not sure I could ever go back to not having it.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 01-20-2012, 12:53 AM   #4
willett
Another Day, Another Dollar
willett's Avatar
2 lo is great if you need to back up a steep incline on pavement
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-20-2012, 07:47 AM   #5
PaRedneckRiders
I did see that JKW Offroad makes a kit to convert the 205 to twin stick but the full kit is $265.00 if i were to do it i think i might just get there rails and make my own stick set up.
Old 01-20-2012, 01:08 PM   #6
snj8198
snj8198's Avatar
I swear I seen one here somewhere
http://67-72chevytrucks.com/vboard/s...d.php?t=503344
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-20-2012, 04:57 PM   #7
PaRedneckRiders
Originally Posted by snj8198 View Post
Haha, ill have to think about it.
Old 01-21-2012, 03:31 AM   #8
Mr. 250r
Mr. 250r's Avatar
My brother uses it mainly to just rip around in fwd just because but I think you lose the lower gearing going to a 205 but i could be wrong but I'm pretty sure a 241 has lower gearing not sure on 208
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 01-21-2012, 04:18 AM   #9
wilkin250r
wilkin250r's Avatar
I see a lot of people talking about 2-LO, and I'll be honest, I use it alot myself. I do a lot of things with my truck, and 2-LO is handy for pulling a car out of ditch or maneuvering a trailer in a tight spot.
However, I don't think a twin stick is necessary unless you actually want to use the front axle alone. 2-LO can easily be accomplished by setting your transfer case in 4-LO and unlocking the front hubs.
wilkin250r is offline   Reply With Quote
Old 01-21-2012, 08:37 PM   #10
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I run an ORD twin stick 205 behind a NV4500. I really could care less about having a twin stick but it was the only easy and durable way to rig up a 205 shifter behind a NV4500. Contrary to popular belief, a 205 is not like a Dana 300 where a twin stick shifter will yield you the ability to do front digs. You must modify the shift rail if you want to spin only the front axle.
From ORD’s website:
“New modified shift rails are not currently available. In the meantime we are modifying stock rails to accomplish the same thing: to get front wheel drive only. We build them up and run them through both the mill and the lathe here, doing it right involves much more than a grinder. Charge is $85 with a $125 core charge (we can wait to receive your rails and waive the core charge)”
You also do not need a twin stick to achieve 2lo. Simply shift the 205 in to low range without locking the hubs as Wilkin mentioned. That gets you 2 low. I used 2low for years in my dad’s wrecker when backing up cars into tight spots as I didn’t have to ride the clutch and the truck would just creep while I concentrated on backing up the towed car. I still use 2 low in the NV4500 often when backing up the driveway into the shop.
BTW….National Drivetrain sells a great reseal kit. For $23 you get ever gasket for every 205 combination in one convenient kit.
DirtyLarry is offline   Reply With Quote
Old 01-21-2012, 08:44 PM   #11
85chevy383
85chevy383's Avatar
I've done it with a grinder just going off pics I found online, works great for me
My 85 build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=497551
85chevy383 is offline   Reply With Quote
Old 01-24-2012, 05:47 AM   #12
1malo68
1malo68's Avatar
I bought the ORD shift rails and twin sticks. I like the idea of being able to do front digs if I need to. With an air locker in front and the right emergency brake set up, you can make some awful tight turns when you need to. Personally, I'd rather have it and not need it than need it and not have it
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 01-24-2012, 08:01 AM   #13
PaRedneckRiders
Ok i was just looking at the ord kit and the parts add up to $295 but jkw sells a kit for $265 is there a difference in quality or is there something else that i am missing?
I also heard that the kits wont work on some of the t-case adapters, which ones does it not work on?
