Still plays with trucks
Crew cab creation option
While checking out CL last night I came across an ad for Suburban parts. They guy is building a crew cab and has a bunch of left over Suburban parts. The only pic in the ad was of his crew cab project.
He has a great idea for building one that will make doing the low roof conversion much easier. Looks like he cut the truck cab in half and grafted the suburban center door pillar section into the middle. All that is left to do for the low roof conversion is the simple single direction curved area in the middle. Should be relatively easy to make compared to the pie cut, bend & blend job needed to make the Suburban front corners and roof skin match the truck roof profile. You could even bead roll an inner roof skin filler panel with features to match the truck to take care of the headliner issue. I need to call this guy and see if I can come take a look at what he is doing. I'll see if he is a member of the board and try to get him here if not. It looks like a good way of doing the conversion as it would keep the truck VIN numbers even for 72's and not cause weird registration issues in states like mine that license SUV's as cars. http://spokane.craigslist.org/pts/2756231048.html
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
![]() Join Date: Apr 2005
Re: Crew cab creation option
He's a member (ATVPRO) and has a build thread in the project section.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks, glad he is on here. I will have to look him up. We live in the same area of town.
