Old 01-20-2012, 11:57 AM   #1
mustangchef
mustangchef's Avatar
My 62
New here , but not to the truck.
Running a 350 with a Munci 3 speed.My 411 is just making the engine spin too fast...what are my options?
mustangchef is offline   Reply With Quote
Old 01-20-2012, 12:21 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: My 62
Welcome to the forum. Easiest solution may be just a rear axle gear swap. Is your truck a Chevy or a GMC? Most of the 1/2 ton GMC's have Dana 44 rear axles and gear sets are plentiful since so many 4x4 & Jeep guys use them.
Another option is swapping in an overdrive transmission. I'm running a 350, Super T10 4 speed and 4.10 rear axle. Works fine in my situation since I rarely take the truck long distances or on the freeway, but if yours is a daily driver getting the rpms down will be much more practical.
Old 01-20-2012, 12:24 PM   #3
mustangchef
Re: My 62
Its a Chevy with a 12 bolt, not a Dana.
Don't stop, its harder to hit a moving target.
Old 01-20-2012, 12:38 PM   #4
1963c-10
1963c-10's Avatar
Re: My 62
Gears are readily available for the chevy truck 12 bolt 8.875 rear ends
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-20-2012, 12:43 PM   #5
mustangchef
Re: My 62
Thank you ,a source? Whats recommended for high way cruising, but not loosing too much out of the hole.
Old 01-20-2012, 01:15 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
Re: My 62
Unless you have overdrive, if you want pleasureable highway cruising and something to get you off the line I would go with 3:43. 3:73 I think are prefect, but only if you have overdrive. Just my .02.
Old 01-20-2012, 01:46 PM   #7
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: My 62
TKO 600 with a .64 OD best of both worlds , I run a 3.91 rear gear and this is a killer set up, not cheap but it works , and is far better than a t-5 out of a S 10 truck. At least for me that is. Those t 5 are extremely weak and where only put behind 305 in the firebirds, etc. Thoese broke often any ways.
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-20-2012, 02:16 PM   #8
1963c-10
1963c-10's Avatar
Re: My 62
Summit, jegs, most of the catalog dealers have them. Also try justdifferentials.com, they have them for $159.00 in several different gears sizes.
Old 01-20-2012, 07:47 PM   #9
62 Longbed
62 Longbed's Avatar
Re: My 62
If your truck still has the stock 1962 rearend , to my knowledge the only gear set available is a 3:38 I beleve in the aftermarket ... The rear mounting is also different on the Chevy 1960-1962 Rearends versus the 1963-1966 rearends . X-Frame versus conventional frame .. Otherwise as 1963c-10 stated , Gears are readily available for the chevy truck 12 bolt 8.875 rear ends .. Good Luck !!!
My 2 cents ...
62 Longbed is offline   Reply With Quote
Old 01-20-2012, 07:49 PM   #10
GMR-PERFORMANCE
Re: My 62
If its the OEM unit it will be a front load diff.
Old 01-21-2012, 12:25 PM   #11
mustangchef
Re: My 62
lowering in replacement motor during holidays.....the other one puked at 70 mph on a cruise into the city
Old 01-21-2012, 01:58 PM   #12
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: My 62
Nice '62
http://67-72chevytrucks.com/vboard/s...d.php?t=361134
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-21-2012, 02:20 PM   #13
mustangchef
Re: My 62
Thanks,......came from a farm in Georgia..bought it form a guy going into the Marines...I had it painted by a Nam chopper pilot 20 years ago...and the new used engine I just bought came from a Nam chopper door gunner. Small world...and it was featured in this Nam cooking video .{.at the start of the video only } http://www.youtube.com/watch?feature...&v=zJuMJlEPxjQ
heres a pic of the motor that threw a connecting rod..it was a nasty explosion with an awesome burst of black oil and smoke .I was lucky enough to have the truck roll up an expressway exit ..down a serve drive and into a parking lot..I had no idea what happened..till i looked under the hood.
Old 01-21-2012, 10:14 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
Re: My 62
It's nice nothing worse happened when that let go, like taking out something important like a tire.
Many years ago a female coworker called me early in the morning before work, asking me to come to a nearby gas station where her car was up on the lift. Her car lost power on the way to work and she pulled in to have it checked. She was afraid the station attendent was trying to take advantage of her. I arrived, looked up, and easily confirmed the bad news since it looked just like yours.
