01-20-2012, 04:02 PM | #1 |
Where can i find 65 GMC sway bars
Im having problems finding sway bars for the front and rear. Just a half ton with the 305 V6. (for now) The few places i check showed it incompatible with the chevy C10.
01-20-2012, 04:48 PM | #2 |
Re: Where can i find 65 GMC sway bars
The front is same as a Chevy, rear is different than Chevy as GMC's usually had leafs in rear. Any 63-87 1/2 ton 2wd front bar should fit.
01-20-2012, 06:43 PM | #3 |
ask around in here:
Vendors Marketplace Early Classic Enterprises sells the bar, bushings and what not. -W |
01-21-2012, 12:13 AM | #4 |
I pulled the one for my 64 off a 73 one ton dually out of the wrecking yard, it's 1-1/4" dia. Bolted right in using all the brackets from the 73.
01-22-2012, 11:44 AM | #5 | |
Thanks for the links. I think im gonna order up that 1-1/4" front for the lowered truck. |
01-22-2012, 11:46 AM | #6 |
Now what to do about the rear? Do they sell a rear sway bar for the chevy with Leaf? I think the GMC has wider leaf springs.
01-22-2012, 04:20 PM | #7 |
try Brothers
01-22-2012, 04:58 PM | #8 |
I would just try the 1.25 front for now, drive it around and see if you actually "need" a rear. Not alot of weight in the rear to sway...
01-22-2012, 06:28 PM | #9 |
i run a front sway bar from a 86 suburan 1.25 and i got my rear sway bar from brothers. i have a 1963 gmc suburan with rear leaf springs..i cut the front springs and used a lowering schackle on the rear.it used to have a 305 v6 but it now has a 454.i think it rides good.the 454 weights less than a 305 v6
01-22-2012, 06:40 PM | #10 | |
How does the Brother rear fit? Any problems? |
01-22-2012, 08:25 PM | #11 |
if i remeber correctly,it just bolted up.i caught it on sale a couple of years ago.i like it.you get use to the way it handles.i forget how bad it use to handle, i tow my 17 foot shasta camper with my surburan.latter ken
