Old 01-20-2012, 08:47 PM   #1
nickv6266
nickv6266's Avatar
14 bolt 6 lug info
I have a 71 swb 4x4 that has the 3/4 running gear under it now . I had previously posted changing back to half ton mainly because i wanted factory rally wheels and do not like any of the 8 lug wheels except the steel wheels. I rescently found a later model 14 bolt with 6 lug axles can anybody give me any info on this axle? Will it fit width wise under my truck? Can I run stock 6 lug rally wheels with this rear? Any info would be great thanks again.
nickv6266 is offline   Reply With Quote
Old 01-20-2012, 09:08 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 14 bolt 6 lug info
It's a 14BSF(14 bolt semi-float). That means it's not a full-float and it's got a 9.5" ring gear instead of a 10.5 ring gear. It's a nice upgrade from a 12 bolt or 10 bolt. But a down grade from a full floater. Your rally's will work fine. The wms to wms(wheel mounting surface)is 67". So depending on what yours is now, it may be wider or just the same. They do make rear disc brake kits for them if you're interested in that sort of thing. Any other questions?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-20-2012, 09:11 PM   #3
nickv6266
nickv6266's Avatar
Well the guy wants $300 for it and i was thinking more like $200 whats a fair price on these. Also do you thing the perches will be the same or will they possibly need moved, What factory gears came in these. Thanks
Old 01-20-2012, 09:18 PM   #4
thirdstreettito
Resident of Here
Perches will most likely need to be moved. The came with 3:07 to 4:56. Usually 3:42 from what I've seen. $200-$300 is fair. The 6-lug ones are desirable.
~Bradley~
Miss having a truck
Old 01-21-2012, 03:14 AM   #5
Mr. 250r
Mr. 250r's Avatar
C clip axles as opposed to full floating bolt on no big deal if you ain't monster trucking it
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
