Old 01-20-2012, 09:21 PM   #1
mooseknuckles
mooseknuckles's Avatar
Wix 33737
What kind of fitting do I need to connect to the outlet side of the wix filter?... is there an -6an adapter fitting for this application? .....I want to run a -6 braided line from the filter to the fuel rail.
mooseknuckles is offline   Reply With Quote
Old 01-20-2012, 09:24 PM   #2
mooseknuckles
Re: Wix 33737
nevermind I found it....pn#640690
Old 01-23-2012, 01:45 PM   #3
terrylgreenjr
Re: Wix 33737
good info
terrylgreenjr is offline   Reply With Quote
Old 02-07-2012, 02:43 PM   #4
Ford Assassin
Ford Assassin's Avatar
Re: Wix 33737
That part number is not for the pic you posted. The part number ypu posted is for 3/8" tube to 3/8" NPT.
However the pic you posted is 3/8" tube to -6AN adapter, part number 640940, which most guys will want to use.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 02-08-2012, 02:53 AM   #5
OldCreek
OldCreek's Avatar
Re: Wix 33737
You could use that original part# with a -6AN to 3/8" compression fitting...but 640940 is probably the easier/cheaper way to go.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-08-2012, 08:57 PM   #6
mooseknuckles
Re: Wix 33737
I got that pic from Russels website?....
Old 02-08-2012, 10:05 PM   #7
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: Wix 33737
I just ordered this and the other two parts to make all three a -6an.
RUS-640850
RUS-640860
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 02-20-2012, 11:35 PM   #8
66ChevyMax
66ChevyMax's Avatar
Re: Wix 33737
Here is what I used,
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 02-21-2012, 10:45 AM   #9
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: Wix 33737
Can you just put compression fittings on the other 2 lines to go to -6?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-24-2012, 01:08 PM   #10
mooseknuckles
Re: Wix 33737
correction on the pn# 640940.....
Old 09-23-2012, 03:27 PM   #11
60 Driver
Re: Wix 33737
Gents,
I am using the WIX 33737 and want to run rubber fuel injection hose from tank to rail. What do I need to connect the 3/8" rubber hose to the filter/regulator?
60 Driver is offline   Reply With Quote
Old 09-23-2012, 03:53 PM   #12
mooseknuckles
Re: Wix 33737
oops
Old 09-23-2012, 03:53 PM   #13
mooseknuckles
Re: Wix 33737
Originally Posted by 60 Driver View Post
Gents,
...it comes with an efi quick connect fitting on the inlet and return, you'll need a fitting for the outlet, similar to the one pictured above without the AN fitting. or a barb fitting.... you can clamp the high-pressure hose onto that. make sure and use the high-pressure hose clamps tho....
Old 09-23-2012, 04:34 PM   #14
60 Driver
Re: Wix 33737
Mooseknuckles,
Thanks for the reply. Got a part # for the "without the AN fitting. or a barb fitting" I am very new to fuel injection. Is there such a thing as a efi fitting to efi fitting? I have rubber hose and clamps rated to sustain 50psi- should be good there. My plan is to connect 3/8" rubber hose with a FI clamp on the inlet tube, and 5/16" on the return side. Am I on the wrong path here?
Old 09-24-2012, 12:22 AM   #15
Mr. 250r
Mr. 250r's Avatar
Re: Wix 33737
Just a quick question on this filter/reg, why is the 5/16 inline with the 3/8 output side, is the smaller of the two considered the feed line going from 5/16 to 3/8 and the actual 3/8 goes back to the tank?
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-24-2012, 12:29 AM   #16
Ford Assassin
Re: Wix 33737
Mooseknuckles,
You need more than basic rubber line. LS motors run on Bar 2 fuel pressure which is 58-62 psi and that is after the regulator. The input side to the regulator could see 100 psi very easily.
The 3/8" connections are for the input from the pump and the output to the fuel rail. The 5/15" is the return to the tank.
Cable
Old 09-24-2012, 12:51 AM   #17
Mr. 250r
Mr. 250r's Avatar
Re: Wix 33737
I was hoping that but i was wondering why is the input from the tank not inline with the output to the rail? Does it have something to do with the regulator or is it just designed like that
2003 1500 Silverado
Old 09-24-2012, 01:29 AM   #18
Ford Assassin
Re: Wix 33737
I am sure it has something to do with the function of the regulator, but you'll have to ask the GM engineering team who designed to confirm.
Cable
Old 09-24-2012, 01:34 AM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Wix 33737
Mooseknuckles,
Ok, stop....you are about 1 weekend worth of work away from starting your truck on fire.
You need Fuel Injection Rated Rubber Line, it is expensive but is rated for high pressures. Regular line will bulge, rip, fray etc, especially around clamps and fittings. This is a great way to have an engine fire.
Please do NOT just clamp the line onto the inlet and outlets on the rails. You need to use fittings.
I have an extra set I can sell you cheap if you need them, otherwise parts store sell them., They are hose barb to Quick connect in 5/16 and 3/8.
You run a FI rated rubber line in 3/8 from the tank to the inlet side using the 3/8 fitting. You run a 5/16 rubber line from the return side of the filter, using the 5/16 fitting, and FI line back to the return on the tank.
From the Output side, run hard line to the engine bay, and then a short piece of FI hose to connect to the Quick disconnect on the rail, also using the correct fitting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-24-2012, 06:11 AM   #20
mooseknuckles
Re: Wix 33737
I would run -6an braided line from the pump/reg to the fuel rail.....
Old 09-24-2012, 11:59 AM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Wix 33737
you would run braided line the 10-12 ft from the tank to the rail? Why? Hard line is still stronger and a 1/4 of the price.
Running braided instead of FI rubber from hard line to rail I do understand.
Old 09-24-2012, 10:44 PM   #22
60 Driver
Re: Wix 33737
Help me Budda! Help me Tom Cruise! BR3W CITY, thanks for helping me keep one of the vital components of the FIRE triangle where it belongs. "hose barb to Quick connect" is exactly the answer I was looking for, I will seek it out.
I do have FI rated rubber hose. It states 3.4bar on the hose(by my calculation 3.4 bar = 49.3128308 pounds per square inch). Am I fine with this or do I need line that will sustain a higher static pressure? i.e. hard line or braided SS
Thanks for the warning and keeping me on the right path. If you have a part # for your recommendation I would greatly appreciate it.
Old 09-24-2012, 11:08 PM   #23
Ford Assassin
Re: Wix 33737
I guess you missed the part where I mentioned that the line between the pump and regulator can see 100+ psi. Regardless 3.4 Bar line isn't good enough. I suggest you carry a decent fire extinguisher with you since you seem hell bent on taking the cheap and easy route.
Cable
Old 09-25-2012, 12:26 AM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Wix 33737
Most FI rubber lines are rated at about 180 psi, I'm not sure what line you have but it isn't FI line, or somehow you have FI line from 25 year ago.
Here is 3/8 and 5/16 from oriellys, note the pressure ratings under the specs.
http://www.oreillyauto.com/site/c/de...0926&ppt=C0222
Old 09-25-2012, 06:33 AM   #25
Ford Assassin
Re: Wix 33737
I meant to put Bar 4 in my earlier post, not Bar 2 (must of had Speed Density MAP sensors on the brain)..
Cable
