Old 01-20-2012, 10:48 PM   #1
tc4x4
tc4x4's Avatar
Removal of axle bearing help? 14 bolt ff
So I got the rear axle out, like I said I'm doing a westernchassisinc.com drop for it, but first I now am doing a rear disc brake conversion. I took the big drums and brakes off, and pounded the studs out of the hub. Now i got the seal, outer bearing, and an inner snap ring out. How do i get the inner bearing out? I can't seem to figure it out. Also how do I find out what my gearing is?
tc4x4 is offline   Reply With Quote
Old 01-21-2012, 12:49 AM   #2
Axleman
Re: Removal of axle bearing help? 14 bolt ff
You have to press it out from the side that the axleshaft bolts to, towards the side that the snap ring is on.
Axleman is offline   Reply With Quote
Old 01-21-2012, 12:57 AM   #3
Axleman
For ratio, look on the OD of the ring gear. There should be some numbers stamped on there. If all else fails, count the teeth on the ring gear and divide that by the number of teeth on the pinion gear.
12-41 = 3.42
11-41 = 3.73
10-41 = 4.10
9-41 = 4.56
8-39 = 4.88
8-41 = 5.13
Old 01-21-2012, 07:12 PM   #4
raceman6135
Dino burner
raceman6135's Avatar
If you're doing a conversion to disc brakes, why are you worried about removing the bearing from the drum? I would spend the extra $10 to $20 and buy brand new bearings.
Just my opinion.
raceman6135 is offline   Reply With Quote
Old 01-21-2012, 09:24 PM   #5
tc4x4
tc4x4's Avatar
I bought brand new bearings, but I was still wanting to figure out how to get the old ones out of the hub, don't i use the same hub to attach to the new rotor???
Old 01-24-2012, 12:44 AM   #6
raceman6135
Dino burner
I guess that would depend upon what conversion kit you're using to make the switch to disks, and what they recommend.
I'm not familiar with any of the kits for the full-floating 14 bolt, but from other disk conversions I've done, they include the hubs, rotors, housing brackets for the calipers, etc etc etc. No need to reuse any of the old parts.
Hopefully someone else will chime in, or check with your conversion kit supplier -- they should be able to tell you if you need to reuse your hub or not.
Old 01-24-2012, 09:04 AM   #7
maskale
brass punch and tap it out. or go buy the special kit made for tapping bearings out. A google seach will pull up lots of info with pics and instructions.
maskale is offline   Reply With Quote
Old 01-24-2012, 02:19 PM   #8
hatzie
Moderator
hatzie's Avatar
You did the hard part when you pulled out the snap-ring. The bearing drives through the hub.
Old 01-24-2012, 04:19 PM   #9
85sierraclassic
85sierraclassic's Avatar
flip the hub over from the pic and drive it out with a small punch, the snap ring its the backside and it holds it from falling in to the inner part towards the inner bearing
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 01-24-2012, 04:28 PM   #10
85sierraclassic
this will show you how, little crude but same idea bout 12-13mins into the vid
Old 01-24-2012, 08:56 PM   #11
mrhino
Just did that when I did a four wheel disc conversion on my crew cab project. Post 50 if you want to check it out.
mrhino is offline   Reply With Quote
Old 01-24-2012, 08:59 PM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Read this conversion page. http://www.shakerbuilt.com/14boltDIY.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-24-2012, 09:19 PM   #13
tc4x4
tc4x4's Avatar
Thanks guys for all the help. I got the bearings out, and for the install of the new ones once I get all my disc brakes conversion stuff in, I will be getting a bearing driver set. So that should make it a lot smoother. Thanks for the tips and the vid!
