Old 01-21-2012, 07:45 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Gas pedal mods
After installing the kickdown cable bracket, my stock gas pedal lever on the engine side of the firewall is not working as freely as it should.
Has anyone installed a later model gas pedel assembly from a 70's or 80's pickup?
If you have pics to show that would be great.
This is something I had in mind.
http://www.ebay.com/itm/85-86-87-CHE...item2c61bfa291
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-21-2012, 09:22 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Gas pedal mods
Don't have any input to offer regarding the later pedal assembly, but it sounds like you may have a problem with the kickdown cable install. I used a standard (cheap) version of the Chevy 350 Lokar kickdown cable and bracket and it worked perfectly for 15 years with the stock gas pedal linkage, until I pulled the cable when I swapped back to a stick shift transmission.
http://www.lokar.com/product-pgs/thr...s/th350kd.html
Old 01-22-2012, 01:47 PM   #3
Fastrucken
Junior Member
Fastrucken's Avatar
Re: Gas pedal mods
I used the gas pedal from an 87 suburban for my 5.3 swap. I just looked and don’t have any pics of the install (truck stored for the winter) but it wasn’t hard. I bolted it onto place, then drilled a hole for the cable. I also remember using a small file to square up the hole to better fit the cable to the firewall.
I also remember buying a pedal from a 70-72 truck but preferred the later style. I think it had something to do with the way the pedal is bent. I do remember both would have worked though
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 01-23-2012, 12:53 AM   #4
Rich 5150 69
Rich 5150 69's Avatar
Re: Gas pedal mods
Can you tell us what was in there before that...it may be just an alignment issue!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-23-2012, 10:15 AM   #5
61_FL_Apache
Who Me?
Re: Gas pedal mods
It appears to be the stock pedal and lever assembly. I will take and post pics tonight when I get home.
Steve
2001 Blazer 4D 2WD
Old 01-23-2012, 10:45 PM   #6
flips72
flips72's Avatar
Re: Gas pedal mods
i put a 72 pedal assemby in mine, the rough firewall is where i made room for my tall valve covers, the square hole i made by drilling a 1/2 hole and used a small flat file to make the corners, hope this helps.
flips72 is offline   Reply With Quote
Old 01-24-2012, 08:04 PM   #7
61_FL_Apache
Who Me?
Re: Gas pedal mods
Thanks Flip! Thats what im looking to do.
Here is a pic from the inside.
Here are a few from the engine side.
You can see the interference I am getting between the kickdown cable bracket and the throttle linkage. It works, but I would like it to work better.
Currently the lever between the rod connected the carb and the firewall moves up and back when pressing the pedal. It hits the spark plug wires and other dist wires. Im looking for a setup like the later models that use a cable and pulls straight back.
Thanks again for the input!!
Steve
2001 Blazer 4D 2WD
Old 01-25-2012, 12:01 PM   #8
doobiebro
doobiebro's Avatar
Re: Gas pedal mods
Depending on the carb and transmission application you got... you can get a kickdown cable mounting bracket that bolts under the carb and you wont have clearance issues....heres a pic....just a suggestion... Also a cheap fix just make the throttle lever longer like my pic. My lever is actually original for v-8 application thanks to a member. just fab yours...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 01-24-2012, 08:49 PM   #9
Clownpuncher
Clownpuncher's Avatar
Re: Gas pedal mods
If not can't you just adjust lengthen the rod and move the rod back some? I had this setup on my Nova and it worked out wel.. I even had the cables ran behind the rod and never had an issue. There really isn't alot of travel needed for that lever.
Or you can have a rod that sits flat then at the last 2" bend it down then back again. This would keep your lever more vertical instead of a 45 it's at now
I cable option will fix it I'm just saying you can make something work with your current setup.
Chuck D
66 C10 LS6/4L65e
Clownpuncher is offline   Reply With Quote
Old 01-25-2012, 12:46 AM   #10
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Gas pedal mods
Lokar ''Eliminator'' Floor Mounted Gas Pedal
http://www.jegs.com/p/Lokar/Lokar-El...50221/10002/-1
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-25-2012, 10:14 AM   #11
61_FL_Apache
Who Me?
Re: Gas pedal mods
I like the Lokar option too, but I need a low buck fix for now.
Steve
2001 Blazer 4D 2WD
Old 01-25-2012, 10:47 AM   #12
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Gas pedal mods
I used the Locar option, it works but I would like something a little less bling and more stock looking, I know, I know, Picky Sh1t!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-25-2012, 12:53 PM   #13
61_FL_Apache
Who Me?
Re: Gas pedal mods
I would rather have my plug wires routed under the linkage like you have there. If I get the wires lower and the linkage up higher, that will solve my issue.
Thanks for the input.
Steve
2001 Blazer 4D 2WD
