Old 04-27-2003, 03:57 PM   #1
Solarus1981
6 cyl to 8 cyl pics?
I have an org. 6 cyl pickup, converted to 8 cyl... but I think the motor might not be in the right place... seems to be too far back. Anyone have any picts on where the motor SHOULD be in a 2wd 67? I'm worried my new HEI wont fit.
'67 LWB C-10, 406 cid th350, dunno what rear end
Looking to rent a house in Puget Sound area, anyone have one?
Solarus1981 is offline   Reply With Quote
Old 04-27-2003, 05:00 PM   #2
67sss
67sss's Avatar
motor mount/hei pics
here ya go!
67sss is offline   Reply With Quote
Old 04-27-2003, 05:01 PM   #3
67sss
67sss's Avatar
pass side
Old 04-27-2003, 05:02 PM   #4
67sss
67sss's Avatar
hei
Old 04-27-2003, 05:02 PM   #5
BobM
You have the V8 in the I6 location. The stock location for the SB V8 is about 3-4" further forward. You'll need the V8 frame brackets and a longer drive shaft. Can usually pick these up a wrecker.
BobM is offline   Reply With Quote
Old 04-27-2003, 11:01 PM   #6
Blue Beard
Blue Beard's Avatar
Why such a big air cleaner...? Is this a 4x4?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-27-2003, 11:07 PM   #7
67sss
67sss's Avatar
big air
why not?!! and that's only a 2wd pickup.327 with 202's, now if i could find some 2'' ramhorns i'd be set.
Old 04-28-2003, 01:23 AM   #8
Jesse 67 c-10
Jesse 67 c-10's Avatar
Hei will fit its tight but you can get it in/out with the cap off. V-8 is better further back, better weight distribution. it would be a lot of messin around just to move it up and you would loose traction. lots have a sb on the 6 mounts.
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 04-28-2003, 09:01 AM   #9
Bernie
I put a V8 in the I6 position about a year ago and have been very pleased with the result. It is true that an HEI distributor will fit, but only just. To adjust the timing involved moving the plug wires on the distributor cap. In the end I went with a Mallory points distributor. Much better.
Bernie
Bernie is offline   Reply With Quote
