Old 01-21-2012, 11:15 PM   #1
chevak20
length of throttle cable
I threw away my broken throttle cable on my 6.2 diesel project, and now I found out there is one shorter and one longer cable. Which one is it? I think it might be the longer kind??
PS. the engine is not in the engine bay either, otherwise it would been easier.
Also, the cable attaches to the bracket facing down from above and down on the injection pump.
chevak20 is offline   Reply With Quote
Old 01-24-2012, 04:04 PM   #2
rcbildr
rcbildr's Avatar
Re: length of throttle cable
If you can get a measurement of the cable I will compare it to the cable on my Burb....my tape measure is at work right now or else I would measure mine for you.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-24-2012, 09:43 PM   #3
chevak20
Thanks for the offer, I appreciate it.
I went to the GM dealer today and got the OEM part number of this discontinued cable-14038644 and then I searched the web and found out it is a cable (compatible to OEM) that several places sell and it measures 39".
I guess this must be the long one, if it fits? Will see...
