01-22-2012, 11:46 AM | #1 |
Minimizing track width while retaining current components
I'm in the process of ordering parts for my current build. I'm swapping a 50 AD body onto a 69 C-10 chassis.
The C-10 front end has ECE drop spindles an ECE disk brake setup. I'm a little concerned with track width, and I'm trying to bring the tires in with backspacing, but I'm also considering going with some different spindles. The ECE spindles brought the wheels out a fair amount, and I've read on this site that there are other drop spindle options that retain a narrower track width. My initial research points at CPP modulars, but are there any others? Is there any chance any of my options would allow me to reuse the ECE disk brake kit that I've already got? Thanks |
01-22-2012, 05:25 PM | #2 |
A guy with a truck
Re: Minimizing track width while retaining current components
CPP is the only outfit I'm aware of that does narrowed spindles- the modulars and the new school/oldschool- both will accept stock brakes. Porterbuilt makes narrow control arms, if you want to keep your spindles...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
