Old 01-22-2012, 12:34 PM   #1
DaHos
DaHos's Avatar
WTB - Big Block Items
72 - BB Mounts CHECK !
72 - Alt bracket - back rod CHECK !
72 - PS Bracket, small back adjuster CHECK !
72 - 2 groove crank pulley CHECK !
Fan shroud - waiting on delivery................
THX MUCH !!!!!
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-23-2012, 06:28 AM   #2
Classic Bowties
Always on the hunt...
Re: WTB - Big Block Items
Well sixty some odd views and no replies yet to your WTB so I went out and dug around a bit. All OE gm big block short water pump goodies, one set of 72 BBC towers/mounts/clams, one lower 4414 BBC inner 2 groove crank pulley for ac applications, one 72 BBC upper alternator bracket rear brace rod and one BBC remote fill p/s rear pump adjuster brace. Everything pictured for $300. plus $20. for insured shipping. Mel
Classic Bowties is offline   Reply With Quote
Old 01-26-2012, 01:28 PM   #3
RaTcheTmasTer
Automania
RaTcheTmasTer's Avatar
72 BB fan shroud. Excellent shape. No damage.
$105 shipped.
RaTcheTmasTer is offline   Reply With Quote
Old 01-26-2012, 02:59 PM   #4
Classic Bowties
$105 shipped.
RaTcheT, nice BBC shroud and a great shipped price, just an FYI we are now over 100 views and four days later with no reply back from Dahos in post or to my earlier sent pm and he has been on the site everyday since I took the time out of my day to pull out parts and post pictures for him. I'll take that as we are probably just kickin tires here on the said wanted parts, or perhaps maybe my above reply w/pics is just your run of the mill/everyday commonly found overpriced scrap metal? . Mel
Old 01-26-2012, 05:17 PM   #5
Midniteotto
Midniteotto's Avatar
Mel, if you don't NEEEEED that shroud, I could really really use it....
Midniteotto is offline   Reply With Quote
Old 01-26-2012, 07:07 PM   #6
DaHos
DaHos's Avatar
Mel No tire kicking, and I appreciate you replying and digging them up. You do go out of you way keeping these parts available. I'm sorry that I had not acknowledged your post or PM. I am looking into all options as these items are not cheap and multiple shipping charges do not help. I have a long way to go in this project so bare with me please....we are all looking out for "Deals" and when they do come around well.............. you know what usually happens.................
Both prices are fair
Hang tight till the weekend I will let both of you know.
1967 C10 SWB
Old 01-26-2012, 07:29 PM   #7
DaHos
DaHos's Avatar
Need some clarification,
Was there a big block pulley set with power steering without A/C?
I'm trying to figure out the belt/pulley setup without A/C. It seems there would be a single water pump pulley, and an offset double crank pulley to line up with the power steering pump, Yes?
If not Ill need the single piggyback crank pulley also.....
Again, thanks ALL !
1967 C10 SWB
Old 01-26-2012, 09:00 PM   #8
Classic Bowties
That pictured bbc shroud was posted by member RaTcheTmasTer, you will have to check with him on availability. I have some big block shrouds pulled but have no interest in trying to ship them, would have to be picked up. Mel
Old 01-26-2012, 09:39 PM   #9
Classic Bowties
Again, thanks ALL !
Hey no problems here, I just didn't get why you were ignoring thread post and then the pm, also I had put a LOL in the reply and it is my understanding when said "" is used you get a free pass to be a smart ass around here. As far as figuring out what you need for your big block setup, all you have to do is ask as there are a bunch of knowledgeable folks around here to help. Up tonight for your viewing pleasure, I happen to have an untouched and recently pulled 72 BBC 402 complete with the OE non-air pulley & bracket setup for you to check out (see below). The non-ac bbc pulleys that you would be after are: water pump one groove #797, inner crank two groove #418 & outer crank ps add on one groove #525. Mel
Old 01-31-2012, 02:40 AM   #10
Classic Bowties
Ok, everything pictured below was sent out fedex ground insured on Jan. 30th., I swapped the one #414 inner crank pulley out for the #418 inner and then added the outer crank #525 ps drive pulley along with the set of 72 BBC towers/mounts & clams, one 72 BBC upper alternator bracket rear brace rod and one BBC remote fill p/s rear pump adjuster brace. Thanks again and let me know if you have any other questions, Mel.
Old 02-02-2012, 12:59 AM   #11
RaTcheTmasTer
Automania
Fan shroud boxed, labeled and ready to go tomorrow. You will get an email from fedex on it tomorrow. Tim
Old 02-07-2012, 12:16 PM   #12
DaHos
DaHos's Avatar
MEl, All items arrived on Sat. Thank You VVVVV very much, D'
1967 C10 SWB
