Old 01-22-2012, 12:47 PM   #1
OKGMC4
OKGMC4's Avatar
5.3 coolant won't flow, help!
The upper hose gets hot all the way into the top of the radiator, but the bottom stays ice cold. I thought maybe a new tstat would help but it turns out the old one may not have been stuck as the new one does the same thing. I have an aftermarket compressor but have double checked my belt routing and all looks good, pump turns counter clockwise. It's full of coolant and the hoses pressure up. I let it get to 210 dgrees it just doesn't open up and flow. Any ideas from experienced folks? Thanks.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-22-2012, 01:27 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 5.3 coolant won't flow, help!
First start up? If so, how did you fill it with coolant? You need to take the upper hose off and fill it through there once the radiator is full to insure there is coolant in the block, otherwise the thermostat won't open because there is no coolant in there.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-22-2012, 01:54 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
x2, I filled my rad, block and hoses then bled and topped off. If you fill rad or overflow only, you probably have another 2-3 qts to add.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-22-2012, 03:52 PM   #4
OKGMC4
OKGMC4's Avatar
I checked and it seemed to be full all the way to the top. It just seemed like the pump wasn't working. I took off the pump and removed the cover to see if the impeller was tight and I swear the fins are turned the opposite way from what they should be. I compared my belt diagram to the factory one and it shows to be the same. All 5.3 engines should be the same right?
Old 01-22-2012, 03:58 PM   #5
harnalien
TruckincrazY
harnalien's Avatar
When I had this problem, I had to fill it up through the upper hose to get water in the block.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 01-22-2012, 05:25 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I agree with harnalien, you need to fill engine first, if you fill from rad, the water can't get into the block cuz it can't displace the air in it. The thermostat isn't in the water so it will never open
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-22-2012, 05:47 PM   #7
AJII
AJII's Avatar
I filled mine from the top hose and still never got water to flow.
Drilled a couple of holes in the Tstat, and everything worked as should. Heat is still nice and hot as well.
AJII is offline   Reply With Quote
Old 01-22-2012, 09:13 PM   #8
OKGMC4
OKGMC4's Avatar
What's odd is I put it all together and ran it for 30 minutes and...
The lower hose never got hot, maybe just lukewarm. The top got hot, I used a digital meter at the cap hole and the water ran 195 to 200. At 200 my fan comes on, it runs till 194 and then off, but the lower is still only warm at most. Gauge never got above 210. Maybe I'm just over analyzing this and it's OK?
Old 01-23-2012, 11:44 PM   #9
ls1nova71
ls1nova71's Avatar
If it's not getting over 210, then you're fine. And yeah, you're probably over analyzing it.
