12 bolt rear 3.73 gears
Have a set that I purchased here and did not use because I also found a set with a posi that I ended up using instead.
These are used with carrier and bearings, races, shims etc, One ring tooth small chip outer edge(small) should not affect operation at all. The carrier is open. $35.00 + actual shipping. Can get pics if any one interested. Thanks Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 12 bolt rear 3.73 gears
3 or 4 series?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Series 4 I believe. Series 4 goes from 3.73 to 4.10.
I also have a Open Carrier Series 3 2.76 to 3.42, I believe. That would be just the carrier. The original post is for both carrier and gears. Thanks for replying. Ron
Rats! Thank bud
Can I see a picture that shows the chip?
Here is some pics
Ron
Couple more
Ron
If you still have the carrier and 3.73 gears can I have a shipping quote to
S9V 1Y4, Canada Thanks Josh |
Ok working now
Thanks for replying Ron Posted via Mobile Device
I have not forgot about you just been super busy. Thanks
Ron
Don't worry I'm not in a rush
