Old 01-22-2012, 02:16 PM   #1
chewychevy67
i have a loose rivet on my hood hinge. how do i tighten it
i have a nos hood hinge and one of the rivets is loose but it is not rounded out. do i have to press it? is it something i can do or do i need to take it to a machine shop?
chewychevy67 is offline   Reply With Quote
Old 01-22-2012, 02:29 PM   #2
pat 70/71
pat 70/71's Avatar
Re: i have a loose rivet on my hood hinge. how do i tighten it
I think you would be money ahead if you just bought a new oem hinge. But if you want to fix it I would recommend checking with an industrial supply type store to see if they carry large flush type rivets if so, drill out the rivet in question & go to the next size up( so the hole is still round) and press in a new one. its all about the tolerance at the rivet (imo,) cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 01-22-2012, 03:23 PM   #3
chewychevy67
It is a nos hinge i bought new from gm a while ago. Thet wouldnt exchangeit for a new one. My hood closes nice but i can move it side to side very easily. I wonder if i just leave it will the rivet wear out quickly?
Old 01-22-2012, 04:28 PM   #4
SactoJim
SactoJim's Avatar
Just take it off and put one side of the rivet on something solid and use a dull edge chisel to try and "mushroom" the head further......did that to mine and it seemed to help.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 01-22-2012, 04:57 PM   #5
pat 70/71
pat 70/71's Avatar
Didn't know it was a new hinge try what this gentleman suggests sounds like it could be your answer. Plus don't over think the movement side to side they all do that at least all mine have to some degree. cheers, Pat
