Old 01-22-2012, 02:21 PM   #1
EPS3
front suspension changes 67-72 to 74-87
Can anyone tell me if the 74-87 C10 has an improved front suspension & brakes over the 67-72?
What are the physical differences?
What are the handling differences?
Thanks for your help.
EPS3 is offline   Reply With Quote
Old 01-22-2012, 03:15 PM   #2
SCOTI
SCOTI's Avatar
Re: front suspension changes 67-72 to 74-87
Physical differences?
Rubber bushings in a shell vs rubber lined steel sleeve offered more isolation for a smoother ride & less vibration being transmitted to passangers.
Bump stops are slightly different because of the slightly different spindles for drum vs disc applications.
Handling?
While the post-72 bushings offer a smoother ride quality, they also will flex more meaning slop/give vs precise alignment when pushed in corners.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-23-2012, 11:34 AM   #3
EPS3
Thanks for the info.
Does anyone know if it is possible to swap 73+ control arms, spindles, & disk brakes on a pre 72 C10?
Old 01-23-2012, 01:52 PM   #4
SCOTI
SCOTI's Avatar
Yep. All will swap....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-24-2012, 11:23 AM   #5
EPS3
Are the front tracks different or the same?
Can someone tell me what the front track is for each range of years?
Old 01-24-2012, 11:54 AM   #6
KrazyRay
KrazyRay's Avatar
I have sold 50 73up disc brake setups for the 67-72 trucks. The best and easiest IMO is to unbolt the engine crossmember (with all of the suspension/brakes) off the 73 frame and bolt it onto your 67-72 frame. You will have to drill a couple of holes to get all 7 on each side fastened. If you don't care about the upgraded bushings, use a 71-72 disc setup on your 67-70.
KrazyRay is offline   Reply With Quote
Old 01-24-2012, 12:32 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Here's some great info for you- "Drum to Disc" conversions 60-70
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-24-2012, 12:35 PM   #8
EPS3
Will the front track remain the same when the cross member is replaced?
Old 01-24-2012, 12:50 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
yes
Articles-
"Refining Sierra"
Old 01-24-2012, 12:53 PM   #10
EPS3
Old 01-24-2012, 04:26 PM   #11
SCOTI
SCOTI's Avatar
6x-70 drum front ends to 71-87 disc get wider. 71-72 disc to 73-87 disc front ends there's no change. The disc spindles & hardware causes an increase vs the drum set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
