Old 01-22-2012, 03:23 PM   #1
mlevario99
Exclamation CPP Motor Mounts and Tranny support question
I just install my 5.3 engine into my 68 suburban, but I notice that on the passenger side the oil pan is rubbing just a bit into the cross member, I install the CPP engine mounts in the front most holes, is that where is supposed to go, or do I need to installed them in the back holes. If I installed them inthe back holes, do I need to drill a hole for the bolt that goes into the cross member. As it is right now, with the motor mounts in the front the tranny support from CPP does not line up with the holes from the chassis.
I am attaching 2 pictures
mlevario99 is offline   Reply With Quote
Old 01-22-2012, 05:30 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: CPP Motor Mounts and Tranny support question
Move it back. You may have to drill for the trans...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-22-2012, 07:06 PM   #3
66ChevyMax
66ChevyMax's Avatar
Put mine the the back holes
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 01-22-2012, 09:05 PM   #4
mlevario99
66chevymax, that is what I am thinking of doing, I will just have to drill a hole in the cross member, since it does not have one there.
Old 01-22-2012, 10:01 PM   #5
66ChevyMax
66ChevyMax's Avatar
That is correct. Take good measurements before you do. That bottom slides in at more of an angle than you think.
Craig
Old 01-23-2012, 11:02 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I would use the ECE mounts instead of the CPP mounts. THey allow you to move the perches from the front to the back without drilling anything. I didnt like the CPP mounts but that was me. I also used the CPP trans mount and liked it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-24-2012, 12:37 AM   #7
mlevario99
well I drill another hole in the cross member and it works, but now have an issue with the cpp tranny support, if I alignes the support the holes in the tranny mount do not line up, so I have to install the support at a littl angle, the tranny is centered but it is at an angle, so I am gone have to look into it, here some pics.
Old 01-24-2012, 10:59 AM   #8
Clyde65
Clyde65's Avatar
I just re-drilled my trans mount holes.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-24-2012, 12:56 PM   #9
66ChevyMax
66ChevyMax's Avatar
I will have to do the same but I'm holding off until I have headers that fit.
Craig
Old 01-24-2012, 02:03 PM   #10
Clyde65
Clyde65's Avatar
The CPP mounts wouldnt allow me to use one set of headers I had, so that is why I went with the ECE perches. they will fit front or back mounting holes. I had to trim my top frame rail but 68-72 wont have to IIRC
Clyde65
Rebuild of Clyde
support our troops!
