Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-22-2012, 07:14 PM   #1
Plunkett
Any thoughts on this?
I've had a couple of projects in the past but never gone as far as putting a motor in a truck. I came up with how I want to build the engine for my truck and I'd like some input on the combo. First off, the truck is a 1972 chevy c10, 2wd, th350 tranny, 12bolt with a 3.73 rearend and 29" tall tires. My direction with this truck is to have something fun to drive that's pretty quick at the same time. I might occasionally take it to the drag strip if I get a wild hair but it will mostly just be a weekend toy. I will list the combo that I want to use on this engine, please feel free to give any thoughts on any of the parts used.
406 sbc
I'm looking to run 9.5-10.1 compression
Patriot 64cc aluminum freedom series heads
Comp cams Extreme energy 274h hydralic flat tappet cam
Edelbrock Performer RPM intake manifold
Holley 750cfm vacuum secondary carb
1.5 roller rocker arms
The truck already has long tube headers with dual 2.5" exhaust.
If I left out any information, please let me know but that's my plan so far. What's everything will work together?
1987 gmc sierra v1500. 350 tbi, 700r4, 6" sky jacker lift, 15" Mickey Thompson wheels, and 35" bf Goodrich km2 tires.
Plunkett is offline   Reply With Quote
Old 01-22-2012, 07:28 PM   #2
redsled87
redsled87's Avatar
Re: Any thoughts on this?
Depending what your budget is, I would put a hyd. roller cam instead of the flat tappet that way, you don't have to worry about what kind of oil you run. Second, I would look at a better set of heads. For example, your running an Edelbrock Perf. RPM intake, I'd run their RPM heads or a set of AFR heads. AFR has a good tech dept. that, you can call or email your comb too. Just my $.02
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 01-22-2012, 10:17 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
What he said , plus a double pump . This is the drag racing section .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-22-2012, 10:29 PM   #4
Plunkett
I realize that this is the drag section, but I felt like I could get better responses on building an engine in this section than the other section. The holley 750 that I'm looking at is a double pumper carb.
