![]() Join Date: Sep 2011
Thrift heater
1964 sb ss I6 230. The wiring for the heater is missing. Need to know how to get to the switch (cable in center, with 3 prongs in the back) from the fuse panel, then to the resister which has 3 prongs & lastly to the blower motor in the engine compartment. A color diagram would be perfect.
Thanks Lary |
Senior Enthusiast
Re: Thrift heater
Although they pertain to the 60-63 heater, perhaps the diagrams on post #50 of the following thread will help:
http://67-72chevytrucks.com/vboard/s...+thread&page=2 Also - can't find a diagram for a 64, but this 1966 diagram might be of value: http://www.64moneypit.pages.qpg.com/...ucks/id17.html |
Re: Thrift heater
Thanks Mark. I have already seen those. I need point to point & the wire
color would be nice. Larry Posted via Mobile Device |
Re: Thrift heater
Anyone?
Re: Thrift heater
I will go out and look under the dash of my 63 today for you and see what Ive got. Im not sure the wiring is the same for 63-64 though
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Thrift heater
Thanks 1963c-10
Re: Thrift heater
Got to busy Larry, will definitely check today for you. I know the orange wire goes from the resistor to the blower motor. Will check the back of the assembly today.
Re: Thrift heater
Sorry, I will have to pull radio and litter container to get to it. Ill try tonight if I get home with any light. Only had about 10min for lunch today and couldn't see anything with all the options in the way. **Correction** The orange wire goes to the blower motor from the switch, not the resistor.
