Old 01-22-2012, 09:42 PM   #1
awbrown
Best power window kit???
I want one that the motor sits in the middle of the door.. or can operate without extending into the vent area of the door,must stay in the area of the window..
awbrown is offline   Reply With Quote
Old 01-23-2012, 10:24 AM   #2
66farmer
66farmer's Avatar
Re: Best power window kit???
I have a Nu-Relic, looks great I haven't insalled yet.
66farmer is offline   Reply With Quote
Old 01-23-2012, 11:51 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Nu-Relic are made with OEM regulators and GM motors, they are supposed to be ( I dont have them) the best and nicest around. They are not cheap ( about $500) but if they work like newer truck PW, then they would be worth it.
I had some cheap universal power windows on my truck and took them out, they worked OK but just rather have the strong arm windows.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-23-2012, 02:58 PM   #4
nomrlz
nomrlz's Avatar
I've went back forth whether to do pw in our 66
I saw a kit that used the window crank as the switch. Was purdy trick
nomrlz is offline   Reply With Quote
Old 01-23-2012, 03:08 PM   #5
Clyde65
Clyde65's Avatar
Nomrlz, I have also seen that, I believe you can have the New-Relics do the same.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-23-2012, 03:12 PM   #6
awbrown
I want to see pics if anyone has them , one that mounts inline with the window is what I need ,has to mount at or behind where the pivot bolts for the window regulator ,I dont want the type that just turn the crank of the old regulator....
Old 01-23-2012, 03:21 PM   #7
jimmydean
jimmydean's Avatar
I was looking at a $100 universal that actually looked pretty good. I will be going with power windows, I'm sure. Not for $500, I would think I could retrofit something for cheaper.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-23-2012, 08:08 PM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Best power window kit???
(( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas
http://67-72chevytrucks.com/vboard/showthread.php?t=402277
Power Windows:
http://67-72chevytrucks.com/vboard/showthread.php?t=403946
63 C10 one piece windows
http://67-72chevytrucks.com/vboard/s....php?p=3768123
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-22-2012, 02:10 PM   #9
CdM
CdM's Avatar
Reviving this one... Trying to figure out how to use the setups out of my 92 chev. Anyone give this a shot yet?
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
