C/10 junkie
Scored today at Pick n Pull??
Ok I think I may have scored today at Pick n Pull.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
C/10 junkie
Re: Scored today at Pick n Pull??
Also Rene the same truck had all the soft ray glass in excellent shape, had the wrong vehicle so I hope its still there on Wednesday. I braved the rain for this already.
C/10 junkie
And I got a super nice pair of bullseye back up lenses. I feel like I have redeemed myself!!
C/10 junkie
Anyone? I'll clean them up today and post some more pics if that helps.
I am a Referee of life.
I can't be sure but they do look like my 250 brackets.There are some spacers not pictured,I hope you got those.There are some differences in the bracket pictured top left in the first picture,offset differs on some.I also didn't see the pulleys.Go get them.It's a major PIA to mix/match a set.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
PanelD is right they do look like the "short" block style....might as well get the pulleys too, after all they most likely did work on the 292. Compare with my brackets...these came off of a 79 Nova non integrated head.
Was there anything else on the 292 (exhaust manifold, auto)? As far as chrome valve cover....I couldn't say GM did that....but it is a good score! I like those valve covers....I just picked one up myself. |
#7 | |
C/10 junkie
#8 | |
C/10 junkie
Get the water pump pulleys.....
and the HB pulleys.... I pulled the timing cover because the timing tab was on the opposite side and some say to maybe get the pump that way you have a core to match up if its a different design also. The rule of thumb........get everything that is associated or otherwise connected to the system. The system I pulled from had a/c, but that was already gone.....3 pulley system. Also get the pump....it has another pulley. |
Heres my greasey mess the moment it came out with pulley attached.
I dont remember any loose spacers on mine either...all spacers were attached to the "bpdy" bracket (the big one).
C/10 junkie
Ok get all the pulleys I can, how about the spacers? I took all the hardware but there was no spacers that I remember.
#13 |
I don't have pics of the spacers.They are just short pieces of heavy wall tube that fit between the pump and bracket pieces.They fit over the bolts/studs that mount the pump to the bracket. Top pic in post #13 shows the offset bent into the bracket.Depending on the pump pulley this can create an alignment problem.If the pump is there,get it also,You may not use it but might need the pulley.
