Old 01-23-2012, 11:26 AM   #1
m455sx
m455sx's Avatar
Cool 1962 front parking light trouble
The driver side 1157 bulb will not blink if the hood is in the down position, once i raise it approx. a foot it will start blinking???? The indicator in dash also doesn't blink at same time but only when i hit the passeger side like im turning right. But the indicator will blink when i hit the driver side even though the front blinker doesn't work. Hopefully yall understood what i am trying to get accross.
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 01-23-2012, 11:30 AM   #2
1963c-10
1963c-10's Avatar
Re: 1962 front parking light trouble
What are they doing when in the park light position ( one pull out from dash)? Sounds to me like a short in the wiring somewhere. Im guessing a brake in the front lamp harness.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-23-2012, 11:40 AM   #3
m455sx
m455sx's Avatar
It does the same thing in park position. I was thinging it maybe the harness.
1970 Cutlass SX
1962 Chevy Stepside
Old 01-23-2012, 12:07 PM   #4
MisterC
MisterC's Avatar
I had similar problems with my right blinker/park lamp. I recently purchased and installed a new harness and it works great now.
$29.95 from Classic Truck Parts. Installed in minutes and looks just like the factory. Money well spent!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 01-23-2012, 12:15 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I'd try connecting a temporary ground wire directly from the battery to either the lamp housing or the ground side of the bulb socket (depending on if the ground is provided by a separate wire in the harness, or through the hood itself). Then raise and lower the hood to see if the problem has gone away. This will isolate whether the problem is a break in the power source, or simply a bad ground.
Old 01-23-2012, 12:36 PM   #6
m455sx
m455sx's Avatar
It has a good ground. It is self grounding when in its place or the light would not light up at all.
1970 Cutlass SX
1962 Chevy Stepside
Old 01-23-2012, 07:21 PM   #7
62 Longbed
62 Longbed's Avatar
I had alot of the same problems with my 62 ... I keep chasing my tail around .. I would fix one thing then I would have another problem , do it again , another problem .. I went ahead and purchased a front new light harness , new signal switch on the lower part of the steering column and installed them , new bulbs as well ... Pulled steering wheel of and also made sure the cast turn signal was in good shape , pivot lubed and all was in tact , screws tightened ... After all this , all works great ... Hope this Helps !!! Sounds like alot , but I got tired of wasteing hour after hour chasing something new ...
P.S. Welcome to the site !!! Very nice truck and a fellow Oldsmobile Owner ...
62 Longbed is offline   Reply With Quote
Old 01-24-2012, 09:52 PM   #8
m455sx
m455sx's Avatar
im orderind a new harness this week. thnx for all the wisdom!!!!!
1970 Cutlass SX
1962 Chevy Stepside
Old 02-08-2012, 10:08 PM   #9
m455sx
m455sx's Avatar
ordered and installed a new harness fixed problem. well worth the $. old harness fell apart.
1970 Cutlass SX
1962 Chevy Stepside
Old 02-08-2012, 10:12 PM   #10
m455sx
m455sx's Avatar
ordered harness from american auto wire and it fit perfect!!!
1970 Cutlass SX
1962 Chevy Stepside
Old 02-11-2012, 05:36 PM   #11
62 Longbed
62 Longbed's Avatar
Glad to hear all is working for you now ...
Old 02-11-2012, 06:18 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I did this too and it solved the issues I had also.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
