Air conditioning control lever repair question
The top slide lever in my control panel is broken. I have searched for repair/replacement threads without any luck. Can anyone help with this?
Thanks, Gary
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Re: Air conditioning control lever repair question
I found this thread useful when I replaced my broken lever.
http://67-72chevytrucks.com/vboard/s...d.php?t=245558
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
Thanks, that's just what I was looking for!
Having been through this I must say that is a great write up.
Those 40 year old pot metal tabs you need to bend and re-use are the biggest issue. Take your time there. One thing I'd like to add is the fan switch. I see in the write up it was replaced. When I went junk yarding for an AC controller EVERY one I saw had a melted switch connector and/or a wrecked switch. Look your switch and switch connector over real good. If there is any sign of melting or a speed or two doesn't work I would order a new switch and connector from LMC or similar then click over to NAPA and order about a half a dozen of part number 725147. This is the wire terminal that clips into an unmelted switch connector. With these parts you can repair all your fan speed wires and button it all back up so it operates just like the day it was delivered. For what its worth, I stock these wire terminals and the "male" connector (NAPA part number 725145) in my electrical box as these are used in most of the connections on this vintage of GM vehicle.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#5 | |
Florida Edition
![]() ![]() Join Date: Oct 2010
I may have a spare lever for you, the top one right? If you haven't already found one I'll dig that box out (need to anyway).
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: Nov 2004
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#8 | |
Gary
Florida Edition
I found my stash and that is the only lever I don't have.
Sorry. Posted via Mobile Device
No problem! Thanks for looking, hope you found some other things you need. I usually do!
Gary
I am a Referee of life.
Get one of the repair kits from a vendor.They're fairly cheap and solve the pot metal lever problem.They use steel llevers.Remove and clean/lube the cables since they are the biggest cause of the problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thanks, I was wondering what the replacements were made of. The original seems to be a steel piece riveted to a cast aluminum piece, and the cast broke. I would think they would never break anyway if the cables and doors were lubed and too much effort was not used on the controls.
#13 |
That looked like why my upper lever broke, the cable was binding and the lever had to be forced. If everything works smoothly, the pot metal will be OK. Obviously the steel ones are more stout and you can go that route if you choose.
Here's a pic of what I found in mine - - - > http://67-72chevytrucks.com/vboard/s...&postcount=158
