Old 01-23-2012, 12:01 PM   #1
savatreatabvr
savatreatabvr's Avatar
BBC Valve Question?
Can the valves not being adjusted correctly on a BBC 454 make it act like it's running on 7 1/2 cylinders? It seems no matter what adjustments I make to the Quadrajet, timing and/or valves it still acts like 7 1/2 cylinders. The reason I say 7 1/2 is because it still idles and runs ok it just acts like it's got a slight miss! Anyone with knowledge on this?
savatreatabvr is offline   Reply With Quote
Old 01-23-2012, 01:24 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: BBC Valve Question?
Valves will have an effect if they are seriously out of adjustment. There is usually some give with hydraulic lifter engines though. It can't hurt to perform a quick valve job though just to be sure.
Old 01-23-2012, 01:41 PM   #3
Metalshapes
Metalshapes's Avatar
I'd run a compression and leakdown test before I would yank the heads.
Rally 'round the family....with a pocket full of shells.
Metalshapes is offline   Reply With Quote
