Old 01-23-2012, 12:47 PM   #1
mightyatom
mightyatom's Avatar
Made a new seat cover
Hi All,
The last couple of weekends I have been working on a new seat cover for the truck. The old cover was ripped and the springs were pushing into the seat foam at the base causing it to sag. Thought I would share what I did in case anyone is on a budget and wants to do it on the cheap. The whole project probably cost $65 for materials, a couple of weekends work and some basic sewing skill (I used my wifes).
We picked up all the material from the discount area of hancock fabrics. The following materials were needed:
vinyl $16
material $18
foam $15
mesh material $8
hog rings $5
I also reused some material and metal wire from an bed boxspring I had dismantled a while back.
The process was as follows:
1. remove hog rings and seats cover.
2. pick thread and break cover into its component parts to use as templates
3. I used the old wires from a boxspring to tie together the top of all the spring across the length of the seat so it would firm up the springs. I used cable ties to tie it together.
4. Lay the mesh material over the springs to stop the springs pushing into the seat foam.
5. I need to patch a bit of the foam as there was a dip on the drivers side so used a bit that was leftover from the seat cover to fill the void.
6. Next layed foam from the old boxspring over the seat foam.
7. Fit the new cover over the seat, pull tight and use hog rings to hold.
Thanks for looking
Jay
Jay
{ 1972 Chevrolet C-10 Fleetside, 350 V8, 5.7L. }
mightyatom is offline   Reply With Quote
Old 01-23-2012, 01:01 PM   #2
big_al_71
big_al_71's Avatar
Re: Made a new seat cover
Good job!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-23-2012, 01:13 PM   #3
yuccales
yuccales's Avatar
Looks great! You guys did a good job.
yuccales is offline   Reply With Quote
Old 01-23-2012, 01:17 PM   #4
tattoed71
tattoed71's Avatar
looks good . great writeup.
paint dont make u go faster
tattoed71 is offline   Reply With Quote
Old 01-23-2012, 03:21 PM   #5
kcsa75
kcsa75's Avatar
My wife has an upholstery business. I always figured you had to have a gift to do upholstery, but it's amazingly easy, especially when you have the old seat cover to use as a pattern.
I've got a seat out of a late model F-250 in my garage that is going in my '72 as soon as she finds time to make me a new "Highlander" seat cover for it.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 01-23-2012, 04:00 PM   #6
mightyatom
mightyatom's Avatar
I agree. I only just bought some center seats from a 99 Chevy Tahoe I was planning to install as it was cheaper than getting a new cover from one of the suppliers. I thought I would try recovering the original seat to see if it was a job I could tackle for future projects. But the seat turned out so good I think I will keep the original and sell the tahoe seats
Jay
Jay
Old 01-23-2012, 06:30 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
It's amazing what you can do if you put your mind to it... Good budget upgrade. Tell your wife she "did good"...
LockDoc
Leon
Old 01-23-2012, 10:06 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Great job.And it almost fits the "Cheap Tricks" thread.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
