Old 01-23-2012, 01:55 PM   #1
sleepchamber
sleepchamber's Avatar
Rallye wheel hub hole....
There is a difference in the center hub hole size between a car rallye and a truck rallye....right? Any old rallye will not fit an '85 C10 will it? I have seen trucks with the five slotted rallye wheels though......
1985 Scottsdale 305/350
sleepchamber is offline   Reply With Quote
Old 01-23-2012, 01:58 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Rallye wheel hub hole....
It's my understanding that car rallys have a different size lug pattern. IE: 5 on 4.5 instead of 5 on 5. or whatever the exact measurements are.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 01-23-2012, 02:19 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
It was my understanding that all chevy 5 lugs were 5 on 4.5. I think F*rds were 5 on 5.
Old 01-23-2012, 02:20 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
And I think as long as they are at least a 15" wheel, they should be able to fit. The 70's 14" rallye wheels will not work because they won't clear the caliper. But I haven't heard of some having smaller hub centers.
Old 01-23-2012, 02:40 PM   #5
trout
full size chevys are 5x5 cars and s1os are 5x4.5
Edited by staff
trout is offline   Reply With Quote
Old 01-23-2012, 03:27 PM   #6
sleepchamber
so as long as the bolt pattern is correct the hole doesnt matter since its not 4X4?
Old 01-23-2012, 03:36 PM   #7
trout
yea long as the bolt pattern patches up and some wheels need sertin lugs but most u can use stock lugs
Edited by staff
Old 01-23-2012, 03:37 PM   #8
Metalshapes
Metalshapes's Avatar
The aftermarket is who makes the 5 hole rallye wheels for our trucks. originally came on chevelles camaros and corvettes all with the same 5 on 4 3/4 bolt circle. The 5 hole rallyes your are seeing are aftermarket only and were never offered on our trucks. You can get them through year one, lmc or wheel vintiques and such.
Rally 'round the family....with a pocket full of shells.
Metalshapes is offline   Reply With Quote
Old 01-23-2012, 03:56 PM   #9
Keith Seymore
Keith Seymore's Avatar
This is correct.
The previously mentioned 5 on 4.5 is a Mopar pattern (or '63 Pontiac Tempest - lol).
Corvette rallys are 5 on 4.75 bolt circle.
2wd truck wheels are 5 on 5.
If you are still curious about the diameter of the pilot hole - I can't address that as I sit here but could measure one of each once within a matter of minutes after I get home. Let me know if you still want to know.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-23-2012, 05:32 PM   #10
sleepchamber
Keith, I would definitely appreciate it. I'm going to look at a set Friday and want to be sure they will fit before I drop any money on them. I measured the hole on the spare which is a rally and it is 3" across.
Old 01-23-2012, 08:02 PM   #11
74 stepside
74 stepside's Avatar
The car style ralley wheels you have seen on c10s are aftermarket wheels. Wheel Vintique, Wheel Smith, Early Wheels, etc. FYI if you find after market wheels with 2 bolt patterns, the are 5 on 4 1/2 with 5 on 4 3/4. Which fit Mopar, small Ford, and small GM. Other wheels with 2 bolt patterns are the 5 on 5 with 5 on 5 1/2. Which fit big GM (c10-caprice-cadillac-etc) and Ford trucks. I believe the center bore hole is smaller on the car bolt patterns.
74 stepside is offline   Reply With Quote
Old 01-23-2012, 08:12 PM   #12
Keith Seymore
Turns out, they are different.
Center pilot hole diameter on a 15x8 truck rally: approx 3.1"
Center pilot hole on a 15x8 Corvette rally: approx 2.8"
K
1979-1986
1986 - 2019
Old 01-24-2012, 01:45 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
seen these used before,duo the hub size tho
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-24-2012, 04:30 PM   #14
74 stepside
Motornut thats a Buick ralley wheel with 5 on 5 bolt pattern.
Old 01-24-2012, 05:12 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
yup just showing what i know works..... shoulda read "duno the hub size"
John
