04-27-2003, 08:24 PM | #1 |
oil leak
I have changed my oil filter twice with two different oil filters. And I still get some oil seapage from around the filter seal? Any thoughts?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
04-27-2003, 08:50 PM | #2 |
BAD BOW-Silverado XST
Use a small screwdriver and clean the block really good. Are you wiping any used oil on the ring? If not give it a try. It will help seal it better and keep the gasket from sticking to the block.
04-27-2003, 09:00 PM | #3 |
I will try the screwdriver idea yes I wipe oil on it it leaks very little not even enough to add in between changes but would still like to stop it.
04-27-2003, 09:08 PM | #4 |
Robert Olson Transport
i would use the razor blade scraper instead of the screwdriver but yeah make sure ya dont get crud into the motor
04-27-2003, 10:37 PM | #5 |
that thing that the oil filter screws on to my be broken, i say that cause a buddy of mine had that problem. then he played hell trying to find the right one. could be loose or broken. i think it called and adaptor or something to that effect.
take of the oil filter and check that thing out real good, see if wobbles or is loose or what ever. also make sure the old rubber seals are cleaned off. thats about all it could be from the oil filter
2004 Silverado Crewcab (Dark Spiral Gray) |
04-28-2003, 11:18 AM | #6 |
"The dude abides"
Check the surface where the filter meets the adapter. Clean it off with the razor or with a screwdriver, just be careful so that you don't gouge it. Check for any gouges or nicks when you get it all cleaned off. Also check to make sure that there isn't an old gasket still stuck to it. Sometimes this happens.
If the mating surface is clean and nick free, then I would clean everything up and make sure that it is actually leaking from that seal or perhaps it is leaking where the adapter meets the block and the oil just runs down onto the filter.
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
04-28-2003, 08:16 PM | #7 |
LED King
Make sure you don't over tighten it or under tighten it. 1 1/4 turns after it contacts the block.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
