Old 01-23-2012, 02:36 PM   #1
squirrely_1
fuel range indication freak out !
hello, i usually don't post about my newer chevy but i am at a loss..My fuel range estimate just starts dropping as soon as i start my truck, then it climbs then it drops and sometimes the fuel needle with follow suit?..I have owned several chevy pickups, and back in the day when your fuel guage started not reading or freaking out then it meant a fuel pump change was in your future. Is this an indication on the newer Chevy trucks? I figure must be a sending unit thing, or is it something simpler? All replies are appreciated !
squirrely_1 is offline   Reply With Quote
Old 01-23-2012, 05:46 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: fuel range indication freak out !
What year truck?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-23-2012, 06:09 PM   #3
squirrely_1
sorry forgot to post the vehicle info
2005 silverado 5.3 crew cab Z71
Old 01-23-2012, 09:25 PM   #4
bwood
bwood's Avatar
How much does the needle move and does it sometimes not work at all?
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 01-24-2012, 02:16 AM   #5
squirrely_1
it moves wth the digital display , by that i mean when the range estimate moves so does the needle
Old 01-24-2012, 10:15 AM   #6
bwood
bwood's Avatar
What I meant was, does the needle act sometimes like it is not working, only shows 1/4 when it's full or pegs out when it low. The digital is a calculation of your remaining fuel * your avg mpg. So if you park on a hill, the fuel level will fluctuate and your miles to E will change also. There is also an that exists where the stock instrument clusters had issues and the needles can go crazy. It comes up often.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 01-24-2012, 02:38 PM   #7
squirrely_1
The fuel needle always works ,never goes to E when it is not supposed to..But my estimated fuel range just goes up and down as i drive the truck , my average fuel economy stays the same as it always has been..The fuel pump is not whining like the 3 other chevy's that i have owned, that i replaced pumps on..But i am approaching the 115,000 mile chevy breakdown.. which is usually 1 of three, Fuel pump , water pump , or power steering pump..But thats just my experience..lol
Old 01-24-2012, 08:41 PM   #8
clinebarger
My 04 does the same thing....There is nothing wrong....Its just the way it works.
clinebarger is offline   Reply With Quote
Old 01-24-2012, 09:52 PM   #9
gmclowsierra
Go to the dealer and get some fuel treatment. The sensor is corroded. The gm cleaner will clean the fuel card.
gmclowsierra is offline   Reply With Quote
Old 01-26-2012, 07:18 PM   #10
squirrely_1
thank you ..i will give it a shot...so this remedies the problem of me having 25 gallons of gas and the indication dropping from full to almost empty then climbing , and so on and so forth?
Old 01-26-2012, 09:16 PM   #11
clinebarger
You said it doesnt go to E??
Old 01-27-2012, 04:13 AM   #12
ncl5047
sending unit?
ncl5047 is offline   Reply With Quote
Old 01-27-2012, 10:59 PM   #13
squirrely_1
it will go to E if i have no gas , what i was trying to say is when i put 20 gallons of gas in at the pump, i know that gets me 325 miles, cuz i have gears in my rear, and i drive in town and i like to hear my flowmasters...lol ..But it will sit at 325 miles for a split second then drastically drop to like 90 miles then bounce back up to 300 , and so on and so forth, and the fuel needle reflects the digital display while it is fluxuating...Does that clearify at all?
Old 01-28-2012, 12:51 AM   #14
bwood
bwood's Avatar
So when the range drops to 90, the needle also drops? If this is the case, I would check the sending unit as recently stated. The range is connected to the fuel level, so if the needle move the range will follow.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
