Old 01-23-2012, 04:25 PM   #1
54blackhornet
54blackhornet's Avatar
Seam Sealer Question
I am in the process of installing a new windshield & gasket on my 68 GMC, Going to let a local glass guy do the install and supply the glass & rubber so he can warranty it. He suggested that we reseal the roof drip area at the time he sets the window,"he has a 72 Blazer" how do you get rid of the old sealer to ensure no leaks down the road ? thanks
54blackhornet is offline   Reply With Quote
Old 01-23-2012, 06:17 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Seam Sealer Question
I dug mine out with a small hammer and screwdriver. It took some time to do. I don't know if it would soften up with a heat gun or not, I didn't try it.
LockDoc
Leon
Old 01-23-2012, 07:23 PM   #3
LakeAnna
LakeAnna's Avatar
LockDoc
I did pretty much the same I got 90% out and then used the sandblaster to get it nice and clean. I realize you won't be doing that so you may want to use a wire wheel on the grinder to finish after all the scraping and digging. It's amazing what you can find under all that sealer...
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 01-23-2012, 07:46 PM   #4
leddzepp
Moderator
leddzepp's Avatar
x2 on the wire wheel
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
