Old 04-27-2003, 09:07 PM   #1
XXL
Seņor Member
XXL's Avatar
Question electric fan sizing
Is a single 16" puller fan mounted in a shroud sufficient to keep the engine cool? Figure a mild big block for engine.
Kenneth
XXL is offline   Reply With Quote
Old 04-28-2003, 05:30 AM   #2
Low69CST
I would say questionable, i have dual 12's that work perfect.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-28-2003, 11:46 AM   #3
miket
miket's Avatar
Ken,
I think it depends on alot of things...I assume you will be using a stock 4 core or aluminum? Electric or, mechanical water pump?
When I installed my 502 I purchased a BeCool module which included twin fans, shroud and radiator...it was expensive but it keeps the motor cool.....I heard Vintage Air (not sure if thats correct) has a twin fan/shroud combo for the 67-72 trucks..
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 04-28-2003, 12:19 PM   #4
lotik
drag it like you stole it
old air
negative camber //LA\\
lotik is offline   Reply With Quote
Old 04-28-2003, 12:24 PM   #5
miket
miket's Avatar
Sorry....I am a goober...I knew it was an "air" vendor....but couldn't remember which.....
Old 04-28-2003, 12:26 PM   #6
lotik
only reason i knew was because i almost bought it. kinda out of my budget at the current time
Old 05-10-2003, 08:59 PM   #7
XXL
Seņor Member
XXL's Avatar
Just posted an ebay seller review relating to the fans I bought the other day...
http://67-72chevytrucks.com/vboard/s...threadid=52263
Old 05-10-2003, 10:40 PM   #8
blazerowner71
Active Member
fan size
like the old saying bigger is better! go to your local NAPA or part master store and look at the back of a fan package some tell what size fan you need. It goes by cubic inch or horse power of your motor I can't remember which for sure. My sons 327 called for twin 12" !
blazerowner71 is offline   Reply With Quote
