Old 01-23-2012, 06:54 PM   #1
YtseJam
YtseJam's Avatar
Looking At A 1965...Opinions?
Always been a motorcycle person, so this is a little new to me....figured I would try to get some feedback from those who know more than I do! I'm looking at a 65 Shortbed with a mildly built 350/350 Turbo Automatic. The motor sounds great and is pretty quick. The body was removed and the entire suspension was replaced, including being lowered. It has a Camaro rear, disc brake conversion in front, 5 lug conversion, tilt wheel, relocated fuel cell in the bed, shaved bed handles, power window conversion as well. Now for the work....needs a bed floor, cracked windsheild, paint, a little rust in the driver floorboard next to the kick panel, a key made for the door lock, it has a floor shift, but there is a hole next to it that needs to be covered....maybe 3" diameter, not rust, just a hole. Seat needs to be done, carpet...mainly cosmetic. He's at 4K. Sounds in the ballpark for what I've seen. I'm relatively mechanically inclined so I would be doing most except for the body and paint. It's going to be a driver, so I'm not looking for perfection....thoughts?
YtseJam is offline   Reply With Quote
Old 01-23-2012, 07:07 PM   #2
kart34
Re: Looking At A 1965...Opinions?
Go for it... well worth that..
edited by staff
kart34 is offline   Reply With Quote
Old 01-23-2012, 07:07 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Buy it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-23-2012, 07:31 PM   #4
YtseJam
YtseJam's Avatar
Kinda leaning that way! Gonna meet with him tonight to take another look.
Old 01-23-2012, 07:32 PM   #5
oem4me
A lot has been done, and it still has a ways to go. I'd say the quality of what's been done is of major importance. The way I see it, If you're going to stray from stock, do it right! Otherwise, undoing someones slop is no better or even worse than starting from scratch. If you are confident the work done is top notch and will not need going over, then add up it's remaining needs and see where you sit. Also, totally finished projects are some of the best bargains out there, because almost no-one gets out what they put in.
Old 01-23-2012, 08:53 PM   #6
duallyjams
duallyjams's Avatar
The main thing is if your happy with it , don't rush haste makes waste , take your time and look it over. Sounds good.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-23-2012, 08:55 PM   #7
YtseJam
YtseJam's Avatar
True, unless they lie to you! Drove 3 hours yesterday to look at a 63 that was "done"...needed nothing. I must have asked this guy every poosible way I could if all was working and in good shape, he finally admitted that the heater wasn't working, but that was IT! I get up there, and the first thing I see is that the Honeycomb Air Cleaner has no paper element, I'm looking straight down into the carb. He said that he had spent too much on it already...huh? But he had only driven it without one for a year! The speedo and gas gauge didn't work, the valve cover was leaking so bad, oil was pooling on the intake. The dual mufflers needed clamps, the pipes were bouncing. He insisted we drive it, so we did....reluctantly. The brakes went almost to the floor, it had a power steering pump...yet no power steering, the exhaust fumes that came into the cab were so bad that after about 4 blocks, I had to turn around and come back before I killed my wife who was sitting in the middle. It had an exhaust leak so bad that a deaf person could hear it...and those are just the things I can remember.
Old 01-23-2012, 08:57 PM   #8
DanSan c 10
DanSan c 10's Avatar
Just crawl under it and look for rust. You know heavy rust ,cab mounts and such. I sure you have, but it is better to know now then after you get home. Other wise go for it.
Why can't I find it until the last place looked?
65 Longbed 283 three on the tree.
66 Longbed 292 three on the tree.Pennys A/C
Trucks made in USA
Buy a much as you can, Made in the USA
DanSan c 10 is offline   Reply With Quote
Old 01-23-2012, 08:59 PM   #9
YtseJam
YtseJam's Avatar
May throw him an offer....I've driven it once, looked at it twice. Want to go over it one more time. The gas gauge still needs to be hooked up from when the tank was relocated, also needs a rear bumper, but I know their not to expensive...I think that's the extent of what it needs.
Old 01-23-2012, 09:00 PM   #10
dracko
dracko's Avatar
Buy it. That sounds like a hell of a deal.
dracko is offline   Reply With Quote
Old 01-23-2012, 09:00 PM   #11
YtseJam
YtseJam's Avatar
That's a good point.....I'll add that to things I need to go over. From a quick glance it looked pretty good, it's a California truck...don't think it's a coastal one.
Old 01-23-2012, 09:04 PM   #12
rbar
rbar's Avatar
To me it seems like a decent price for both the buyer and the seller. If I was in the market, I would probably buy that, but also try to work him lower on the price just to see if I could save some money, but still buy it if not. The body looks pretty good which is the biggest thing to me and it sounds like it has some improvements, if they are done right. I like the way it sits too.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 01-23-2012, 09:07 PM   #13
YtseJam
YtseJam's Avatar
So do I! Story is the guy worked for a suspension shop, the owner bought from him...at which time he completely rebuilt the suspension. Since the bed floor isn't there, you can see the components look brand new, thing rides excellent. The owner bought it back, and now just needs it gone.
Old 01-23-2012, 09:12 PM   #14
jocko
jocko's Avatar
If the seller has done the mods you're wanting to do to a stocker if you were to buy one - then probably a very good deal (for you). If you want to turn it into a resto truck, then it'll cost more to un-do stuff than to buy a stocker. My assumption is you like what he's done - so, yeah, look at rust and quality of work - then go for it. And post pics of it in the process!
Old 01-23-2012, 09:15 PM   #15
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I'd throw $3k at him, harp on all the needed bodywork and see if he meets you in the middle.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-23-2012, 09:34 PM   #16
YtseJam
YtseJam's Avatar
He actually started at 6k, couldn't do it. I was gonna throw $3500, probably would have gone 3k as well if he didn't start so high. After yesterday's fiasco, I got back in touch with him...that's when he went to 4k.
Old 01-23-2012, 09:37 PM   #17
YtseJam
YtseJam's Avatar
Definately will! The motor sounds ridiculous, has a cam, 650 Edelbrock, Flowmaster 40's, love the floor shift....all these things I would have done.
Old 01-23-2012, 10:10 PM   #18
joedoh
joedoh's Avatar
that truck is worth 4k all day long if it runs and drives.
I bought a nissan from a guy who liked dream theater a really lot. his front tag was ytsejam, I had to leave it on because he had jacked up the truck by the bumper and without the tag you could see the bend.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-23-2012, 10:25 PM   #19
protrash64
protrash64's Avatar
I was wondering about D/T too...
Old 01-23-2012, 10:27 PM   #20
YtseJam
YtseJam's Avatar
That it does....very well!
Still surprised he let it go! Fans are extremely loyal.....
Old 01-23-2012, 10:30 PM   #21
YtseJam
YtseJam's Avatar
Been a fan since Images and Words back in 91, see them everytime they play the Warfield in San Francisco. Met them once, all of them could not have been nicer....nice to know some of you guys are familiar with them, most of the time I get the deer in the headlights look.
Old 01-23-2012, 10:35 PM   #22
firefighter736
firefighter736's Avatar
Definitely check those outer floors/rockers and underneath for the cab mounts/braces. If it has rust at the kick panels I'd bet for some in the outer floors. Nothing a little welding can't fix! Sounds like a real nice truck, though. I dig the stance. Hope it works out!
"All anybody wants is a normal life and a cool car... most people settle for the car" - Christopher Titus
1966 Chevy C10 Pics
Rust to Riding - Pictures of my build
firefighter736 is offline   Reply With Quote
Old 01-23-2012, 10:39 PM   #23
Andyboy
Andyboy's Avatar
KILLER deal, grab it. If you don't get it let me know where it's at. I'm looking for one.
Andyboy is offline   Reply With Quote
Old 01-23-2012, 10:41 PM   #24
YtseJam
YtseJam's Avatar
The rust isn't all that extensive, just where you would normally find it in a truck 46 years old! Your 66 is sweet.....looks great!
Old 01-23-2012, 10:42 PM   #25
YtseJam
YtseJam's Avatar
Will do....although I think it's a done deal.
Appreciate all your input in this....really helped a lot! Some great info here as well, thanks for the welcome!
