Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-23-2012, 09:20 PM   #1
kevinc
kevinc's Avatar
1965 Cab & Long Bed Frame
1965 Cab for sale. In overall decent condition. Cab has chalk marks on the engine side of the firewall. I don't know if they are from factory or not. Solid overall condition, but the only rust thru is in the floorpan near both kickpanels and passenger side rocker panel and a couple small spots near the driver's rocker panel. Everything else is surface rust. Cab corners and door jambs are solid. Driver side rocker panel seems solid. Passenger side rocker panel is rough.
Firewall, dash cowl sides and wiper cowl area is in very good condition. Transmission tunnel and center section of floor and area under seat is excellent. Back panel and inner roof panels of cab are very good condition. Windsheild flange has only surface rust. Area under front of roof is solid. Someone a long time ago did install roof lights, so there are 6 small screw holes in the roof panel.
The only dents on the cab are on the passenger side rocker panel, 3 on the cab back panel and one below the rear window on the inside.
Unfortunaltely the truck cannot get a Texas title. The truck was impounded before the previous owner purchased it from police auction. I ran around with the TX state DMV trying to get one and after 2 months, it concluded with it not being possible to title in Texas. In TX once a vehicle is impounded or deemed a nuisance vehicle, it cannot get a title. It may be possible to get a title out of state, but I'm not sure.
I have several pictures I can e-mail if you're interested.
$150 or throw me an offer for what you think its worth. CAB IS SOLD!
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 01-23-2012, 09:39 PM   #2
kevinc
kevinc's Avatar
Re: 1965 Cab & Long Bed Rolling Frame
1965 Long Bed Rolling Frame. Only surface rust. No rust thru anywhere. There isn't any damage or repairs to the frame that I can see. I cannot measure diagonal to see if its square or not because the cab is still currently attached. If you help me remove the cab, then we can take a measurement.
All frame rails look straight with no bends or wrinkles. All cab mounts are solid. By all appearance, the frame doesn't appear to been hit. Transmission cross member is missing, but everything else is there. All joints and grease fitting are caked in dirt and grease. Probably came from a very dusty part of the state. Steering gear is pretty sloppy. Steering linkage seems tight. It has 4 wheel drum brakes and 12 bolt rear end. I haven't removed the rear cover to see what the gear ratio is. I never had a chance to drive it so I can't say how the rest of the suspension feels. Someone did weld on steel brackets to the rear of the frame for an aftermarket bumper, but they should grind off without any damage to the frame because they did a really bad job welding them on. Wheels and tires included.
$200 or throw me an offer for what you think its worth.Frame is SOLD!
Old 01-27-2012, 03:22 PM   #3
rsmarr1982
rsmarr1982's Avatar
Re: 1965 Cab & Long Bed Frame
will you sell just the cab? if you are willing to ship at my cost i will offer you $200 for the cab.
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 01-27-2012, 04:06 PM   #4
kevinc
kevinc's Avatar
I'm okay with that. I just don't have any idea how a cab would be shipped. Kinda big for Fed Ex to handle. Any suggestions?
Kevin C
Old 01-27-2012, 04:19 PM   #5
rsmarr1982
rsmarr1982's Avatar
Kevin C
it would have to be shipped by truck. i work for a distribution center im a truck driver. i have a guy at work getting me quotes. im just waiting to hear back. thanks robert
Old 01-27-2012, 10:37 PM   #6
kevinc
kevinc's Avatar
Cab sold to rsmarr1982 pending payment.
Thank you,
Kevin C
