Old 01-23-2012, 09:55 PM   #1
el_guapo
Cool Trailer wiring? Where do I hook the bastard in?
Hey gang. Moving forward in my project done on my
own. I'm now trying to set up wiring for a small trailer. Are these
Simple to install? If so where do I run the wires to. Thank you for your patience as I've never tried this before.
Anthony
el_guapo is offline   Reply With Quote
Old 01-23-2012, 09:58 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Trailer wiring? Where do I hook the bastard in?
Part stores sell a T that plugs in by the tail lights to get the lights working, for brakes you will have to run a wire from the pedal.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-23-2012, 09:59 PM   #3
Goldfinger
Goldfinger's Avatar
If you don't have them from stock just go underneath and tap tap into the rear light harness. Find which ones go where then solder the connections. so not that hard.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 01-23-2012, 11:30 PM   #4
yousesteers
If you are going to do just light get one of the plug and play kits you unplug your bed from the frame and this kit plugs in between the bed and frame. You are done If you are going to do brakes do the same thing and then buy a break controller I like the Tekonsha Voyagers, then follow the directions in the box for the brake controller basically one wire to hot, one to ground, one to pedal switch, and one to the plug.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 01-24-2012, 12:16 AM   #5
MalibuSSwagon
I went the easy route and got the t-connector plug and play unit, this just plugs inline with your tail light harness at the rear of the truck. It was $16 from Napa.
MalibuSSwagon is offline   Reply With Quote
Old 01-24-2012, 12:38 AM   #6
el_guapo
Looks like plug and play's my huckleberry. Thanks guys!
