01-23-2012, 10:19 PM | #1 |
Getting stubborn rear shackle off...Help
So I'm trying to take my leaf springs off in the rear with out taking the bed off for now. The upper bolt in the end of the leaf spring can't come out due to the frame rails are in the way. The lower shackle bolt where it connects to the shackle hanger to the frame is the bolt I have to take out then i can lift the leaf springs out with the shackle still attached.
The lower shackle bolt is seized in there. What have others done to get this bolt out of there? Tips would be handy! |
01-23-2012, 10:32 PM | #2 |
Re: Getting stubborn rear shackle off...Help
Air chisel with a punch in it.
01-23-2012, 10:39 PM | #3 |
4.5" cut off wheel on the grinder.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-23-2012, 10:55 PM | #4 |
You're gonna need heat, abrasion, leverage and cussing to get that apart.
01-24-2012, 01:59 AM | #5 |
Could you fit a sawz-all blade in there?
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
01-24-2012, 09:02 AM | #6 |
01-24-2012, 02:36 PM | #7 |
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift 2000 silverado extended cab stepside 5.3l. Stock for now |
01-24-2012, 02:42 PM | #8 |
Arrived on a Pale Horse
That's what I did to my CC truck, but I had the bed off. Definitely some cussing will be necessary
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
01-24-2012, 02:56 PM | #9 |
I use Kroil to penetrate the rust and use an impact hammer to drive the bolts out. I use this stuff at work and it is great. If that doesn't work I usually get out the old torch as suggested before. But Kroil is the best penetrating oil I've ever used. http://www.kanolabs.com/
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
01-24-2012, 03:00 PM | #10 |
On one of mine I used a plasma cutter to cut the back of the shackle off. I then could get to the gooey center.
01-24-2012, 04:56 PM | #11 | |
