Old 01-24-2012, 04:18 PM   #1
paul mora
CPP or ECE
I am installing a 6.0 in my 71 Suburban I would like to leave my air conditioning pump mounted low with the existing mounts and stock exhaust manifolds.
I bought an adapter plate that hits my pump bracket on the passenger side and I decided that it my be better to buy other perches and mounts.
Has anyone done this and which mounts should I buy?
Pulatoy
paul mora is offline   Reply With Quote
Old 01-24-2012, 04:40 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: CPP or ECE
I got them from ECE, they allow for moving front or back frame holes. CPP doesnt, you have to drill. besides CPP has had alot of customer service issues, ECE is always there to help
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-24-2012, 10:11 PM   #3
paul mora
Re: CPP or ECE
I talked with both this morning CCP now makes theirs Adjustable and Early Classics did not lmention the adjustable. Neither one could tell me I caould keep the pump in place and not change the exhaust. CPP is 80 dollars less.
Pulatoy
Old 01-25-2012, 09:00 PM   #4
paul mora
Re: CPP or ECE
I went with the ECE system they said I could use the low mount pump my pan would clear and would need a sloghtnmodification to use my stock exhaust. The price in the catalog is wrong and they gave me a great deal. Stan said to call back anytime.
Pulatoy
Old 01-26-2012, 09:28 AM   #5
68Stepbed
68Stepbed's Avatar
Re: CPP or ECE
That's what I like about ECE. They do what it takes to keep your business. Their products are usually much better as well. At least IMO, they are.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
