Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-24-2012, 07:16 PM   #1
69trk
69trk's Avatar
just ordered my turbo
borgwarner s475..... how do you guys think this will work with a 5.3 with stock rods w/arp bolts, stock pistons w/blower rings, zo6 cam, good springs on the heads....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 01-24-2012, 07:46 PM   #2
HEI451
Re: just ordered my turbo
Keep the boost down to 6 psi or so, good EFI with pressure retard, should do well.
HEI451 is offline   Reply With Quote
Old 01-25-2012, 08:35 PM   #3
'72customdeluxe
http://www.theturboforums.com/smf/th...-500whp**/385/ Just an example of how well truck motors do. Only had valve springs replaced, and I think he ran almost 20 pounds of boost. It popped due to hardware being dropped into the motor I believe.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 01-25-2012, 10:59 PM   #4
69trk
69trk's Avatar
I plan on doing more than 6lbs of boost.... Motor work is going to include a ZO6 cam and better springs, ls9 head gaskets, arp head studs, new helfire rings, arp rod bolts looking for 600rwhp. These ls motors are pretty stout....
1.58- 60'
11.37- 1/4 @115.81
Old 01-25-2012, 11:14 PM   #5
mongoose
mongoose's Avatar
run lots of meth on stock pistons.. and a veeerrryyy good tune.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-28-2012, 01:01 PM   #6
69trk
69trk's Avatar
Here it is
1.58- 60'
11.37- 1/4 @115.81
Old 01-28-2012, 05:41 PM   #7
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
If you were shooting for just 600whp then i would have went with a smaller turbo. The S475 has tons of boost lag.
ProStreet68SB is offline   Reply With Quote
Old 01-28-2012, 07:32 PM   #8
69trk
69trk's Avatar
i will be happy with just 600...According to the turbo guys on yellowbullit this is what i was told i would be happiest with...
1.58- 60'
11.37- 1/4 @115.81
Old 01-28-2012, 11:29 PM   #9
Wild83C10
Wild83C10's Avatar
What's the AR on the exhaust side? If it's the stock 1.32 then you may not see boost until 3500+ rpm. If it's the 1.10 housing then it will be better but still a big turbo for that size motor and only 600 as the goal. 600 will be easy with that turbo.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-29-2012, 10:35 AM   #10
69trk
69trk's Avatar
it's a 75mm compressor, 96mm turbin wheel, 1.32 housing, standard cover... If i don't like how it spools, i can install a quick spool valve. Plus if i want more power later, it's there!!
1.58- 60'
11.37- 1/4 @115.81
Old 01-29-2012, 02:57 PM   #11
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
your short one turbo
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-29-2012, 09:26 PM   #12
ProStreet68SB
1 turbo > 2 turbos
