Old 01-24-2012, 07:39 PM   #1
BabyBlue
The Peacemaker
BabyBlue's Avatar
4-wheel discs?
Anyone running 4-wheel disc brakes? Looking to see what kits you guys used, ease of installation, and whether you had to change your brake booster and reservoir. Any help appreciated. Thanks!
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 01-24-2012, 09:12 PM   #2
bikes&bowties
bikes&bowties's Avatar
Re: 4-wheel discs?
Hydroboost stock everything. Assembled 3an braded lines from parts I ordered from summit. 84 chevy k20 front calipers and rotors. And rough stuff specialty brackets. I will be getting an electric line lock for my e brake when I put the manual in. Prop valve is good but that varies.
http://www.ruffstuffspecialties.com/catalog/14BSRW.html
bikes&bowties is offline   Reply With Quote
Old 01-25-2012, 01:32 AM   #3
Mr. 250r
Mr. 250r's Avatar
Re: 4-wheel discs?
91 3/4t burban with stock D60 up front and stock 05 FF 4 wheel discs didn't change brake booster or proportioning valve etc the pedal is a little spongy but I also did an extremely quick brake bleed just to get it moving, no kits here but there is a company that sells hardware to use late model disc brakes with the original e brake like I did in my 14 bolt swap should be a link
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
