Old 01-24-2012, 08:46 PM   #1
jagee
Got a question for you guys running tall valve covers
I've been helping my friend rebuild the 383 in his 62 pickup. He has decided to run roller rockers which require tall valve covers. We were wondering what all has to be done to keep them from hitting the firewall. The motor mounts are already in the front two holes in the frame. Do you think we will have any problems since its already been moved forward?
jagee is offline   Reply With Quote
Old 01-24-2012, 09:41 PM   #2
T Smith
T Smith's Avatar
Re: Got a question for you guys running tall valve covers
With the engine forward you may not have any interference, but roller rockers don't necessarily require tall valve covers.
T Smith is offline   Reply With Quote
Old 01-24-2012, 11:37 PM   #3
rbar
rbar's Avatar
I'm running tall valve covers for rollers and the engine is in the original holes. It touches and chips paint when hitting the gas, but ok so far. I'm moving it forward soon because I'm changing the drive train anyway.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 01-25-2012, 12:33 AM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Got a question for you guys running tall valve covers
Running tall valve covers on mine.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-25-2012, 02:12 PM   #5
jagee
That's the same set we are gonna run. Did you have to do anything to the firewall or maounts to get them to fit?
Old 01-26-2012, 07:15 PM   #6
jagee
I see that you don't have power brakes but does it looks like there would be enough clearance for a brake booster?
I just got my valve covers today and I was also wondering if the little tabs that hang off the bottom of the valve cover are supposed to fit over the head because mine don't.
Old 01-26-2012, 09:23 PM   #7
rbar
rbar's Avatar
There's enough room for a brake booster.
1965 Chevy swb 383
Old 01-26-2012, 10:04 PM   #8
1Bad62Pro/Street
Arrow Re: Got a question for you guys running tall valve covers
Well Bud,
I have a Mustang II IFS Clip on my front of my truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=484620
Mustang II IFS Suspension (Manual Rack Steering) with 2" Billet Aluminum Wheel Spacers. Heidts MP-042 - Superirde Front Coil-Over Shocks for Mustang II Suspension
Coil-Over Spring Rate (lbs/in) 500 lbs./in. 2” drop Spindles and the wheelbase has been extended to 117"
The motor mounts are homemade. Due to the Mustang II IFS Clip the total ride height of the entire truck and the engine set up is customized and set to the Mustang II IFS Clip. I had some BumpSteer I had to take care of. Actually I have to raise it a half an inch or an inch more in the front to make it ride better. I can't lower the rear anymore because the geometry will be off of the front end. Man I need air ride system!
I had tall valve covers on my 283 before the IFS Clip and engine swap and I didn't have any troubles as I can remember. So from what you have set up it looks like you will be ok.
This is my setup:
555-50145 JEGS Performance Products 50145 - JEGS Valve Cover T-Bar Wing Nuts - Chrome Steel
350-4207K Edelbrock 4207K - JEGS/Edelbrock/ARP Elite Series Dress-up Kit - SB-Chevy Elite Series Dress-Up Kit
Old 01-26-2012, 11:38 PM   #9
jagee
Awesome setup man! I got the same dress up kit today. I've got them home powdercoating them now pretty much the same color as your truck.
Old 01-26-2012, 11:44 PM   #10
1Bad62Pro/Street
Sounds good.
Let's see a picture of your truck!
I wish the Elite Series valve covers came polished. I could send them to Advance Plating to have them chromed.
Old 01-27-2012, 08:45 PM   #11
jagee
I honestly don't have a picture of it. I'll take one of it on Monday when I go back to work. I'm keeping it tucked back in the corner and work on it after hours.
Old 01-30-2012, 01:19 AM   #12
jagee
Here are the valve covers and air cleaner. I coated them in a color called Mirror Yellow and then did the whole thing with clear powder. These should never need polished.Name:  DSCN2914.jpg
Old 01-30-2012, 09:30 AM   #13
1Bad62Pro/Street
Talking Re: Got a question for you guys running tall valve covers
Here are the valve covers and air cleaner. I coated them in a color called Mirror Yellow and then did the whole thing with clear powder. These should never need polished.Attachment 864188
Very nice Bud.....
Old 01-31-2012, 10:42 PM   #14
jagee
Finally got the motor together this afternoon. Gonna get it started tomorrow and hopefully get the truck going in the next few days.
Old 01-31-2012, 10:47 PM   #15
flips72
flips72's Avatar
engine looks great, i had to dimple my firewall but my mounts are in the back holes, no trouble with the power brakes though.
flips72 is offline   Reply With Quote
Old 01-31-2012, 11:00 PM   #16
1Bad62Pro/Street
Looks good Bud!
We need more Yellar '62's on here!
Old 02-01-2012, 08:49 AM   #17
T Smith
T Smith's Avatar
Looking good! Let's see some more pics of the rest of the truck!
Old 02-01-2012, 09:44 AM   #18
1963c-10
1963c-10's Avatar
Looks great...cant wait to see it installed
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-01-2012, 11:05 PM   #19
jagee
I don't have very many but here are the ones that I do have.
Old 02-01-2012, 11:32 PM   #20
1Bad62Pro/Street
What flavor yellow is that?
Old 02-01-2012, 11:36 PM   #21
1Bad62Pro/Street
Is your grill chrome or anodized aluminum?
Old 02-02-2012, 12:11 AM   #22
jagee
The grill is chrome. My buddy just bought this truck a few weeks before the motor blew. I'll have to ask him what the color is but I doubt he even knows.
