Old 01-24-2012, 09:02 PM   #1
WI65gmc
66 GMC pics finally
WI65gmc is offline   Reply With Quote
Old 01-24-2012, 09:10 PM   #2
WI65gmc
Re: 66 GMC pics finally
valve cover is now a gauge pod and the radio and below is the rear diff with flames and you can see my coil over shocks
the center counsil im making
mr tailing arms with laser cut stainless flames neons behind them
with the lights off
Old 01-24-2012, 10:08 PM   #3
likaroc13
Rollin' Old Skool
cool...thanks for sharing
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-24-2012, 10:11 PM   #4
Sneaux
Sneaux's Avatar
Looks like your off to a good start. Is that the original gauge panel with new gauges? I have the same panel but haven't found an aftermarket replacement. I want new gauges but didn't think they would fit in the factory holes.
Sneaux is offline   Reply With Quote
Old 01-24-2012, 10:49 PM   #5
WI65gmc
Ya the gauges are from Harley davidson it's going to be some interesting electrical work to get them running
Old 01-25-2012, 01:09 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm interested to see that center console come along.
Whats with the neon trailing arms tho? Is it stock trailing arms with some sort of cover? The pic looks like its held in place with hardware. I'd be worried about the neon tubes cracking the casing, but I suppose certain brands have much thicker casing so it may not be an issue. You can always go LED pretty easily.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-25-2012, 01:19 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
very cool!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-25-2012, 03:38 PM   #8
WI65gmc
the trailing arms are stock but i welded them where as they were normaly pressed and as for the covers i had a chunk of stainless with that design laser cut to fit i made all the brackets...as for the neons they are held in with some flexible plastic mount and there is some foam type padding hidden behind the stainless hopefully this will be enough support and cushion for them
also if you look in the picture of my gauge pod there is two aircraft toggle switches im planning on running the neons to one of them.... below the gauge pod are two led skull license plate bolts that are on the same switch when the neons are on the skulls eyes light up just so i can remeber when they are on i wouldnt want to get pulled over for that
Old 01-25-2012, 05:10 PM   #9
1963c-10
1963c-10's Avatar
Some nice fab work going on. I like the use of the valve cover to hold the extra guages and radio
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-25-2012, 08:21 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Makes more sense about the trailing arms.
Just noticed your in Janesville, I used to go there all the time when I went to school in Whitewater.
Old 01-25-2012, 10:36 PM   #11
WI65gmc
Nice do you ever bring your truck to any of the shows around here?
