Old 01-24-2012, 09:47 PM   #1
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Fat Tire All Out 60-66 Pro-Street Thread
I want to start a Pro-Street thread for all of us that are taking the big step of Flintstone Fatty Tires in the rear and power plants most dream of in the front...
Anyone have new photos to add of their real for real 60-66 pro-street trucks?
Mine is in literal pieces everywhere inside and outside my house and I need some inspiration.
Here are the motor and bedsides I have to use. Yes I am using 58-59 bedsides on my 63...
I just like being different.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-24-2012, 10:46 PM   #2
Delmo
Delmo's Avatar
Re: Fat Tire All Out 60-66 Pro-Street Thread
Well gues we gotta go back in time for this one. Circa 1992
Pulled over by the Federallies.
Delmo is offline   Reply With Quote
Old 01-24-2012, 11:07 PM   #3
66-PMD-GMC
66-PMD-GMC's Avatar
Very Cool!
Projects..
440CID 2X4 Pontiac
Old 01-27-2012, 12:46 AM   #4
66-PMD-GMC
66-PMD-GMC's Avatar
Possibly an interesting story,
I sometimes amaze myself with my own stupidity.
I have these 58/59 bed sides.. I thought for sure they had the same lines as the 63 cab...
So I am out there moving things around in my build area and I have bed sides leaning against the wall and I happened to look over and saw that the bedsides are not even close....
What the was I thinking??????
Not sure where I got the idea they were the same but I was sure full of ... well we all know what I was full of.
Back to the drawing board.
Projects..
440CID 2X4 Pontiac
Old 02-04-2012, 11:42 PM   #5
66-PMD-GMC
66-PMD-GMC's Avatar
So where are the prostreet trucks???
Projects..
440CID 2X4 Pontiac
Old 08-26-2014, 09:27 AM   #6
66-PMD-GMC
66-PMD-GMC's Avatar
It's been a while since I have posted.
Tomorrow is a big day.
I'm dragging my newly built chassis for my 63 home.
Epoxy sealer ready, chassis black frame paint behind that... excited would be an understatement. ....
I'm going to be building it clean and pretty this time...
It might take longer waiting for paint to dry but once it's done, it's done this time.
My motor is wrapped and patiently waiting...
Photos coming soon...
Projects..
440CID 2X4 Pontiac
Old 08-27-2014, 10:51 PM   #7
66-PMD-GMC
66-PMD-GMC's Avatar
Went to pick up my newly finished chassis from the media blaster today...
He hadn't even touched it yet.
It was supposed to be done no later than Monday... Last Monday!
So needless to say... no photos of the newly applied frame paint...
Dude!
Projects..
440CID 2X4 Pontiac
Old 09-27-2014, 09:09 PM   #8
66-PMD-GMC
66-PMD-GMC's Avatar
I'm really stuck on the fence.
I have a blasted and painted stock frame,
and I have the newly finshed "back half" chassis. .
The narrowed chassis is for my 63 Prostreet.. the stock frame is for my 66 shop truck..
I'm selling off all of my extra 60-66 parts and I'm finally getting down to just my 63 and my 66...
I want to put the widest tires I can on the 66 shop truck but I'm not sure I want to cut up the frame.
Does anyone happen to know what the biggest tires are that will fit comfortably under a fleet bed using a 63-66 frame?
I was thinking of running a 295/50/15 or I have a set of 29X15 mickey Thompsons but I'm fairly sure I'll need to narrow the frame...
I'm not sure I want to do that.
Any suggestions? ?
Projects..
440CID 2X4 Pontiac
Old 09-27-2014, 10:37 PM   #9
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Any suggestions? ?
Really?
I've got some 315/35/20's under the rear of mine, along with 2-1/2" exhaust, check my thread...But you need to widen the rear tubs.
Modges'66 is offline   Reply With Quote
Old 09-28-2014, 12:55 AM   #10
Captainfab
60-66 Nut
The 29 x 15.5 will fit no problem. You should be able to go with the 29 x 18.5 even without modifying the frame. Might have to remove the bumpstop though. Of course that is for a fleetside. The stepside fenders are a little narrower. The other thing to look at is the coil spring clearance.
Old 09-28-2014, 12:34 PM   #11
66-PMD-GMC
66-PMD-GMC's Avatar
I'm not using springs on the stock frame.
I'm thinking of using a later static air suspension similar to a Lincoln Navigator. That along with a watts link.
Removing the bump stop would help clearance..
I should have a bed put together by next weekend to get some real time measurements...
The bigger the better is my thought...
Projects..
440CID 2X4 Pontiac
Old 09-28-2014, 12:41 PM   #12
66-PMD-GMC
66-PMD-GMC's Avatar
Originally Posted by Modges'66 View Post
Really?
I don't know how to compare 20's to 15's but that sounds bigger than the 295/50s I was thinking of using
Projects..
440CID 2X4 Pontiac
Old 09-28-2014, 10:24 PM   #13
duallyjams
duallyjams's Avatar
most tire web site have tire charts that give all the dimension
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-28-2014, 10:46 PM   #14
66-PMD-GMC
66-PMD-GMC's Avatar
Yeah I looked for an app... found a nice one that compares 2 tires to each other.
Projects..
440CID 2X4 Pontiac
Old 11-03-2014, 09:41 PM   #15
66-PMD-GMC
66-PMD-GMC's Avatar
I've decided to go with mickey thompson sportsman radials.
6650' s 26X8 for the front and the 29X18 6650's for the rear on my 63 prostreet.
I have yet to figure out what I can use on my 66 shop truck.
My big question is. .. where are all the 60-66 Prostreet pickups???
Post some photos fellow Prostreeters!!!
Projects..
440CID 2X4 Pontiac
Old 11-06-2014, 04:53 AM   #16
azdude1964
azdude1964's Avatar
Chris, I'm running a Mickey thompsons 18 x15x29 tire on mine with a little clearancing on the wheel well flange . cut off the axle bump stop and trim the flange and you got it. 52 inch axle flange
to flange 14x15 rim with a 4 inch back space
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 11-06-2014, 09:02 AM   #17
Gary V
Active Member
Gary V's Avatar
Got a fat tire build going on using MT 29 X 18.5 bias ply's. Will post more pics as soon as I get set up in the new shop and can work on it again. Here's a link http://67-72chevytrucks.com/vboard/s...d.php?t=625387
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 11-06-2014, 09:29 AM   #18
66-PMD-GMC
66-PMD-GMC's Avatar
Is that a stock frame??? I really like the fat tire look.
I'm using a GMC frame under the shop truck minus the leafs.
should have lots of room.
That will be a nice build.
definitely post some pics.. ;-)
Projects..
440CID 2X4 Pontiac
Old 11-06-2014, 09:36 PM   #19
azdude1964
azdude1964's Avatar
ok here it goes , stock frame , trailing arms with soil overs behind a ford nine inch. shocks are 5 inch stroke(strange) 250lbs springs custom panhar bar and brackets for shocks.
Old 11-07-2014, 07:37 AM   #20
66-PMD-GMC
66-PMD-GMC's Avatar
I have an original 63 GMC frame that I'm doing a leaf to trailing arm conversation on.
I'll be running coil overs and a watts link to keep it up and straight.
I got word yesterday from BF Goodrich that the 295/50/15 tires will be back in production in mid November. This was my original choice for tires on the rear of the shop truck.
I'm running a 3.54 dana 60 and a 700R with 4L70 internals to beef it up and a 360 inch dual quad all Pontiac motor...
with so many builders going with the 22-24 inch slammed a frame/rocker scraping route... I'm trying to do something different, something unique. ..
I'm just waiting for other Prostreet builders to chime in... where are you guys hiding?
Lets see some Prostreet bad boy trucks posted here! :-)
Projects..
440CID 2X4 Pontiac
Old 11-07-2014, 07:43 AM   #21
66-PMD-GMC
66-PMD-GMC's Avatar
Where is that truck now??? In the distant past???
Projects..
440CID 2X4 Pontiac
Old 11-12-2014, 12:11 AM   #22
azdude1964
azdude1964's Avatar
Hey man , you going to Dino's or the goodguys show?
Old 11-12-2014, 11:19 AM   #23
66-PMD-GMC
66-PMD-GMC's Avatar
I want to hit goodguys yes.... will I have the time? Who knows.. lol
Projects..
440CID 2X4 Pontiac
Old 11-12-2014, 10:21 PM   #24
66-PMD-GMC
66-PMD-GMC's Avatar
I don't have any info on Dinos
Projects..
440CID 2X4 Pontiac
Old 11-13-2014, 11:09 AM   #25
aggie91
I'm just glad to be here!
aggie91's Avatar
Here is the link to Dino's Pre-Show Git Down...
http://67-72chevytrucks.com/vboard/s...d.php?t=641861
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
