01-24-2012, 11:49 PM | #1 |
Front susp. Swap
Hello, Okay to fill yall in, Im working a 65 chevy been in the family since the year. Okay well Im down to the chassic. And about done spraying the frame. I know that chevy trucks can fit and what not on most other frames.
Well my question is what years fit front suspen. parts for a 65 chevy I want to end up bagging and put in disc brakes. I know other ppl clip the truck with a camero and what not. But Im pretty good with the grease work and body work but I a newbie with a welder and stuff like that. Any help would be great thanks in advance. |
01-25-2012, 08:59 AM | #2 |
67-72 parts collector,…
Re: Front susp. Swap
Edit:
See post #7 below,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-31-2012 at 11:52 PM. |
01-25-2012, 10:56 AM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
All you really need to swap is the spindles/brakes/power steering/sway bar/ ball joints/ tie rod ends. Like Lolife99 says, read the thread he provided and you will almost be an expert.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-25-2012, 11:09 AM | #4 |
Link didn't work
Posted via Mobile Device |
01-25-2012, 11:52 AM | #5 |
Don't clip it. You'll be in for a ton of work trying to get the core support, steering, inner fenders, and all the body panels to fit right.
Find a '73-'87 parts truck or frame and swap out the entire front suspension, including crossmember. No welding required. You just have to drill two new holes and elongate two existing holes. 'Gotta love Chevy. You can't do that kind of stuff with a Ford.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-31-2012, 11:44 PM | #6 |
thats what I was worried about. support and fitting fenders and supports back again. Thank you so much
01-31-2012, 11:50 PM | #7 |
Sorry.
Just use the Google tool bar at the top of every page,... (today,... 8,090 hits on the subject of crosssmember swaps) Highlight the 67-72 radio button. http://www.google.com/custom?domains...D%3A1%3B&hl=en
